V1 cathode cap and filtering
mrkrausman
Post by mrkrausman » Tue Apr 26, 2011 1:02 am
I am currently running shared cathode (820/220uf). My amp is a little bassy and too harsh and clean on the highs. I use only bright channel on Vol 7-8. Would lowering my V1a cathode cap help? What could I try to boost around 300-500Hz and lower bass response just a little. In other words, I would like to fatten up my lead sound. Also how would lowering the filtering from 50/50 to 33/33 affect the overall tone?
Miss those Metro kits terrible!
Metro 50 Watt
1980 Marshall 2203 JMP MkII
Mojotone 4X12 Scumback H75 M75
toner
Re: V1 cathode cap and filtering
Post by toner » Tue Apr 26, 2011 10:34 am
Lowering the bypass cap to around 3.3uF will reduce boomy bass and tighten it up. It won't really add the mids you mentioned though.
Going to lead spec split cathode will add mids and sound a little smoother.
What's your tone stack? 56k/250pF? If so, switching to 33k/500pF will add upper-mids and gain.
mrkrausman
Post by mrkrausman » Tue Apr 26, 2011 12:18 pm
toner wrote:Lowering the bypass cap to around 3.3uF will reduce boomy bass and tighten it up. It won't really add the mids you mentioned though.
Thanks. Tone stack is 33k/500pF. I have tried both a few times and seem to like shared cathode better.
Metro 50 Watt
syscokid
Post by syscokid » Tue Apr 26, 2011 5:08 pm
mrkrausman wrote:... Also how would lowering the filtering from 50/50 to 33/33 affect the overall tone?
Any response to this part of mrkrausman's question?
mrkrausman
Post by mrkrausman » Mon May 16, 2011 11:11 pm
Well I re-installed a split/shared cathode switch like I had in the past. Right now I can say that I like the smoothness of split cathode sound. It also seems to be middier and less boomy. I think I have a good foundation to work from now.
Metro 50 Watt
