Hey guys...getting a reading of 124 at V3 pins 3 and 8. All other pins read just a bit hot but accceptable. Any ideas?
Kevrockitt
Hot reading on V3
- toner
Re: Hot reading on V3
Check the 470 ohm and 10k that connect to those pins. Also check the points mentioned here:
http://forum.metroamp.com/viewtopic.php ... 41#p360741" onclick="window.open(this.href);return false;
including the presence pot ground.
As always the forum comes through!!! Thanks Toner! It was a bad solder joint at the cap on the presence pot.
Again...you ROCK!
Kevrockitt
Again...you ROCK!
Kevrockitt
