Hi all
I call all my repro builds a Metro and thid is not really a Metro build but would not have been made without this community
A long time ago I asked Brian Wallace which 50W was his favorite. He pointed me to this; http://marstran.com/68%2010513.htm" onclick="window.open(this.href);return false;. which he happens to own.
Anyway; I remembered Michael Doyle stating that the 68-69 50w was also his personal favorite so I decided to give it a try..
Here it is; Marstran chassis,trannies and choke. Sparky front. Valvestorm rear. Brian H. board. Mojo cab - I think. All new components..
It's a truly cool amp that have much gain on tap - but sounds great. It's wide open on all controls and this is the first amp I've made/owned which sounds best that way.
BTW I forgot to install the bright cap and made a bias circuit with a pot - apart from that it should be a faithfull replica of Brians amp.
Pics below
A '68-'69 50W
A '68-'69 50W
JTM45/100
JTM 100 Black Flag
12000
Soldano SLO
Soldano/Caswell X99
Groove Tubes Trio
VHT Classic
VHT 2150
Tone King Falcon
JTM 100 Black Flag
12000
Soldano SLO
Soldano/Caswell X99
Groove Tubes Trio
VHT Classic
VHT 2150
Tone King Falcon
Re: A '68-'69 50W
Ver nice, Reidar! I'm working on mine which will be a replica of the exact same amp, funnily enough. I see you've mounted the impedance and voltage selectors from the rear. Never thought to do it like that, but it looks very cool and more vintage!
Re: A '68-'69 50W
I thought that was a nice touch - yes
It required some work on the selectors because the small brass bolts are not long enough. The Valvestorm rears are thicker than for example Georges - but it ended up looking very very good - so it was worth it.
What pre tubes should I try for this amp??
I have; RFT, Telefunken, Sylvanias, Raytheons, Brimar, Mullard and RCA's...
Reidar
Reidar
JTM45/100
JTM 100 Black Flag
12000
Soldano SLO
Soldano/Caswell X99
Groove Tubes Trio
VHT Classic
VHT 2150
Tone King Falcon
JTM 100 Black Flag
12000
Soldano SLO
Soldano/Caswell X99
Groove Tubes Trio
VHT Classic
VHT 2150
Tone King Falcon
Re: A '68-'69 50W
I'd try Mullard or Brimar in V1, Brimar or RFT in V2, and Telefunken in V3.
