jmp 50 output transformer orinatation
Posted: Thu Mar 03, 2016 12:50 pm
by shackman
Just got half way through my latest build and noticed I have put the output transformer back to front meaning the primary is facing the output tubes. Will this make any difference to noise i.e. hum etc?
I've made a really neat job and don't want to mess with it if I don't have to.
Re: jmp 50 output transformer orinatation
Posted: Thu Mar 03, 2016 4:39 pm
by danman
I don't believe that it will cause you any issues because the OT is still at a 90 degree angle to the PT.
Posted: Fri Mar 04, 2016 1:56 am
by shackman
Thanks Danman, just wondered why it's always with the secondary pointing towards the output tubes, maybe the cable run is shorter for the output?
Posted: Fri Mar 04, 2016 12:27 pm
by shackman
Well just finished the amp and it sounds great, no hum or noise issues.
I did change the V1 coupling cap to a .0022 instead of the .022 because it sounded a bit dull.
It has a lar/mar ppimv on as well, great amps!
Posted: Fri Mar 04, 2016 2:31 pm
by danman
Glad to hear that it's working well!
