chassis for 50 watt
- tooloud
chassis for 50 watt
starting new project 50 watt plexi...... dont know witch chassis to get the steel or aluminum...... used the aluminum chassis for my metro 69 100 watt.......... do the 50 watt panels fit both chassis's.......
"Bend it till it sounds good"
18 Watt TMB Head
JTM45 clone
Metro 69 100 Watt
50 Watt Ceritone metro mix
2X12 Straight & Slant Stack
4X12 V30's & G12H30's
BF Champ
18 Watt TMB Head
JTM45 clone
Metro 69 100 Watt
BF Champ
Been there
No, the aluminium chassis is for a JTM45 only and only those panels will fit. Every thing else fits fine but the panels are way out. You could have a custom cut out made for your headcase to cover the bare bit of chassis at the front but does not seem ideal to me.
The metro plexi panels fit my original steel chassis absolutely perfectly and I presume that Georges new steel chassis matches these.
I made this mistake and had half built my new amp into an alloy chassis (fortunately had not drilled or enlarged any holes pending arrival of the panels).
George is sending me a steel chassis for my project, which means I have a spare alloy chassis for a JTM45 project (although I had planned a 12xxx series next)
- tooloud
