Amp layouts, courtesy of BillyBatz
Guest
Post by Guest » Wed Feb 22, 2006 2:49 am
Hey Billy, just wanted to say "Thanks" for the beautiful layouts.
I'm currently restoring a 76 1986 for a friend, who wants it converted to a 1987 and ordered the board from George and found your layout super helpful.
So - as one of the 2k "hidden" downloaders: Thanks a million times.
Olaf ("Duesentrieb" in many forums)
my website
http://www.thinlizzy.de
Billy Batz
Post by Billy Batz » Wed Feb 22, 2006 8:23 am
No problem. Good luck with whatever you use them for.
franc
Post by franc » Thu Feb 23, 2006 5:31 am
Thanks for the layouts Dan. Very useful for my '69 1959 build
I must admit I'm not using George's kits, but his instructions and your layouts are very helpful to me.
Franc.
"I live my life like there's no tomorrow"
sub
Post by sub » Thu Feb 23, 2006 10:44 am
8)
Thank you Dan! :D
GibsonMarshallCelestion
Lou
JTM 45 Layout
Post by Lou » Sun Feb 26, 2006 9:44 pm
Hey Dan have you thought about doing a layout for a JTM 45 ???
Thanks Bro
You tottally Rock
The Layouts are so damm amaizing...Thank you once again for taking the time to do those up...
Lou
Toronto Canada
Metro 1959 X 2; Metro 1987 x 2 ; Metro JTM45; Metro '68 12xxx x 2;Metro 412 Slant 12M Heritage
1980 Gibson Heritage Elite WCR Pickups; 1980 JVSquire Strat; G&L Legacy ; Metro 412 Slant G12M Heritage
www.houseofnot.com
Billy Batz
Post by Billy Batz » Mon Feb 27, 2006 3:05 pm
Next up, HiWatt DR-103 layout. I started it yesterday and hopefully I can finish it tonight. Itll be a mix between the Reeves layout and the Joyce layout.
Yes and no. I did the 100s because at one time the forum was litered with repeat questions about wiring the filter cans up and the fuses etc... and then the power boards of the early amps etc... The MV's were just a huge mess of confusion. Then the 50s were popular demand :) 45s are even less complex then 50s and so people dont seem to need them. Im not against doing them though.
sub
Post by sub » Mon Feb 27, 2006 5:40 pm
Billy Batz wrote:Next up, HiWatt DR-103 layout. I started it yesterday and hopefully I can finish it tonight. Itll be a mix between the Reeves layout and the Joyce layout.
:shock: Very cool Dan! :D
rockstah
Post by rockstah » Mon Mar 13, 2006 11:55 am
Dan,
while working alot with 2203 preamp lately i was reading a schematic and it doesnt seem to follow your layout as far as how V1a and V1B are wired. my questions are with where the input and volume go as well as the .68/2.7k - 10k.
the 2203 schematic dated 19-5-88 shows the input going to v1a and the preamp volume going to v1b as well as the cathode res/caps going to opposite sides.
any reason you chose a different way then the schematic shows?
i notice you have everything swaped but plates does it matter?
as im trying to better understand reading schematics this has me confused ;)
thanks,
Mark
Billy Batz
Post by Billy Batz » Mon Mar 13, 2006 6:03 pm
One thing is that it doesnt matter which triode you put the stages on. I could put stage one on V2a and it wouldnt effect anything other then opssibly being tougher to route wires. The important thing is that I believe though marshall did it both ways at some point, stage 1 was more often on V1b then V1a. In fact, you cant assume that just because the schematic file has the first gain stage physicaly first from left to right that that should mean its that way on the amp. Most schems arent labeled. The 81 factory schems dont have it labeled with stage 1 on V1a but they do have it on V1b. Not being a tech I cant validate which was done most often. I think it may be something as simple as when the amps changed to 800 series with a PCB change maybe they changed it then to ther way I have it.
As far as the cathodes I believe the very few schematics that are out there taht show the 10k on stage one are in fact wrong or possibly from very early 2203/4's. I dont know of any official schems that are that way. Actually I dont think there are any at all. The only place Ive seen that is the incorrect Metro CD layout.
Heres a few schems
http://www.drtube.com/schematics/marshall/78331-1.gif
http://www.drtube.com/schematics/marshall/jcm800pr.gif
You can see on the second factory schematic the triodes are clearly labeled the way I have it in my diagrams. With stage 1 and 2 labeled as V1b then V1a respectively. The 10k is always stage 2.
Hope that clears it up. Im not a tech so I had to rely on my own research.
rockstah
Post by rockstah » Mon Mar 13, 2006 8:46 pm
Dan, thanks as always for cleary some thinsg up there!
woud ity be ok to put the 68k on the input on the 2203 on the board or should it go how you have it layed out? does it make a difference noise/osilation wise?
Mark
Billy Batz
Post by Billy Batz » Mon Mar 13, 2006 9:29 pm
Yeah of coarse. Although from watching so many people here do 2203's then tweak them with more gain it seems the most practicle thing to do to keep the circuit stable is to have the 68k on the tube socket and use a sheilded wire from the input tip to the socket.
rockstah
Post by rockstah » Mon Mar 13, 2006 10:51 pm
Billy Batz wrote:Yeah of coarse. Although from watching so many people here do 2203's then tweak them with more gain it seems the most practicle thing to do to keep the circuit stable is to have the 68k on the tube socket and use a sheilded wire from the input tip to the socket.
sounds good and thanks!
MacGaden
3033 downloads..
Post by MacGaden » Thu Mar 16, 2006 2:07 pm
Hi Billy:
Your schematics have been downloaded 3033 time now... If we only had charged a couple of bucks for them...
Good to see there´s some use for them, and my webspace was just sitting there doing nothing.
Maybe they should be included on George´s site in the future. There seems to be a demand for high quality layouts.
MacG.
Billy Batz
Post by Billy Batz » Thu Mar 16, 2006 2:17 pm
He did have them on the CDs but they were old versions. Theres beena lot of revisions. Listed on the first page of this thread in case anyones wondering.
Bainzy
Post by Bainzy » Tue Apr 18, 2006 10:12 pm
On some of the layouts there is a wire coming from the first mains filter cap ground that goes to a pair of turrets, connected to nothing. Is this for the 'snubber caps' to go across the board?
If so, is it like this?
turret furthest in top-left corner of board (with blue wire) connects to .22u cap, which connects to the furthest turret in the bottom-left corner.
turret next to that top-left turret (also with blue wire going to SB switch) connects to another .22u 630v cap, which connects to the turret next to the furthest turret in the bottom-left corner
ie. wire up the board like George's 69 PTP board in the store pics
Shred Guitar
