Amp layouts, courtesy of BillyBatz
rockstah
Post by rockstah » Fri Aug 18, 2006 10:13 am
Lou wrote:Billy I have your layout diagrams and like everyone else I am truly thankful that you have taken your time to make those drawings. I have built a '68 12xxx series metro amp and I am unsure what the best Grounding Layout to use as the filter section is different than a 1959.
Do you have any suggestions for me?
Thanks in advance
Lou
v1-v2 cathodes grounded on pot buss between the input jacks and first volume pot -
the pot grounding buss( the presence pot is not in this buss ) should be grounded to the choke screw under the main board closest to the front of the amp. run a wire from your buss to this screw with a lug there
preamp cap on main board goes to same screw as the pot buss
pt grounds on PI cap screw closest to the front of amp along with the bias supply and mains grounds.
screens ground along with PI cap and presence on the other PI cap screw towards the back off the amp.
the ac plug gets its own screw and lug ( i threw a lug on one of the PT mounting screws.
happy building!
Mark
Lou
Post by Lou » Fri Aug 18, 2006 11:25 am
Thanks Dan...dO YOU have a link for the Aiken amp layout or grounding description?
Lou
Toronto Canada
Metro 1959 X 2; Metro 1987 x 2 ; Metro JTM45; Metro '68 12xxx x 2;Metro 412 Slant 12M Heritage
1980 Gibson Heritage Elite WCR Pickups; 1980 JVSquire Strat; G&L Legacy ; Metro 412 Slant G12M Heritage
www.houseofnot.com
NitroLiq
Post by NitroLiq » Fri Aug 18, 2006 12:21 pm
jtmjtm45
jtm 45 layout
Post by jtmjtm45 » Mon Sep 11, 2006 1:49 am
Billy I built my first jtm with help george as well as the jtm 45 forum,but If they would have had a jtm 45 layout of yours it would have even been better.maybe you could do one??? thanks in advance
Billy Batz
Post by Billy Batz » Mon Sep 11, 2006 4:30 am
I guess I may soon enough. I may have more time soon but there are JTM45 layouts like mine out there. Plenty actually. Its why it was low on my list of priorities.
MacGaden
Post by MacGaden » Sun Oct 29, 2006 3:21 pm
8504 downloads and counting.. There
MacG.
Post by VelvetGeorge » Tue Nov 14, 2006 3:54 pm
Yes there is. And I know I'm months overdue to help host them...
Let me see if Bash can get them copied over to our new server.
VG
MacGaden
Post by MacGaden » Tue Nov 14, 2006 4:36 pm
It
MacG.
Billy Batz
Post by Billy Batz » Tue Nov 14, 2006 5:02 pm
Wow. Im glad and I hope it helps keep the tech questions down.
Maybe you can add Mike's layouts to taht folder as well. Or Mike, you can send them to me and Ill add them to the folder.
RedHouse
Post by RedHouse » Thu Nov 16, 2006 11:22 pm
Which PDF is of a 12xxx series board? (filename please)
I'm guessing it's the "67-68 Super Lead Layout.pdf"
MacGaden
Post by MacGaden » Fri Nov 17, 2006 1:36 am
RedHouse wrote:Which PDF is of a 12xxx series board? (filename please)
Yep.
MacG.
RedHouse
Post by RedHouse » Sun Nov 19, 2006 9:51 pm
Thank you.
