above I tried to say that the redplating is always on the push side, this side is normally - but NOT necesarily - driven by the 82k. when swapping plate sides in the PI, the 100k side was redplating.flemingmras wrote:...
Roe...your original post makes absolutely no sense. Re-read it...there's a conflict in it -
You state that "the redplating is ALWAYS on the PUSH side"...(i.e. the side driven by the 82K), however when you swap the tubes to different sides it switches to V6-V7, which is the 100K driven side. So how can the redplating ALWAYS be on the 82K driven side if the problem follows the tubes when you swap them to the 100K driven side?Roe wrote:two tubes redplates on the 480v setting. usually these are v4 and v5 but the redplating changes to v6 and v7 if I swap [the] sides [of v3's plate wires]. the redplating is always on the push side (not the pull side), the side that normally is connected to the 82k in the pi.
I'm expecting oscillation (or too much AC in the output stage) in this amp. different tubes all redplate. in some cases I've gotten 3-4 four output tubes to redplate.
edit: I dont think its AC. at least this amp has less AC under load than my 67 100w
