metro loop return level pot
Where is the best place to add a return level pot with the metro loop? I see the mojo loop has a spot on the board to add a return pot. Should I just add a pot in the return wire to the PI input?? What value would you guys recommend? A 1 meg audio pot?? The reason for the pot is I have an amp with a Jose master and I would like run the master volume up to about 11 oclock and use the return level as a master volume so the loop get a strong signal. Thanks
Re: metro loop return level pot
Interested as well. Figured I'd just bump this thread.
