Preferred Speaker Load.
hdahs
Post by hdahs » Tue Dec 04, 2012 8:45 pm
Figured I would post this here as well:
Using a 47k connected to the 8 ohm tap on my 50w build, is there a cabinet load (4,8 or 16) that sounds better or has any advantage over the other.
The reason I ask is that I am going to buy a couple of Scumbacks for a 2x12, and typically I buy 8 ohm speakers so with a 2x12 I have the option of parallel for 4 ohms or series for 16 ohms. Or would it be better to get 16 ohm speakers in parallel for an 8 ohm load?
Thanks for the input!
stef
Re: Preferred Speaker Load.
Post by stef » Tue Dec 04, 2012 9:30 pm
i like 47k to 8ohm tap nfb, but I use a 4 x 12 cab, the speakers are wired series-parallel for total load of 16 ohms :what:
julkke
Post by julkke » Wed Dec 05, 2012 2:03 am
My cab is 4 ohms and I have often wondered if it sounds that much different than being wired to 16ohms in series parallel or whatever was the better sounding way. :D Jim from Scumback sure has an answer to this one too.
