Zero-Loss FX Loop is leaking
cellphone
Post by cellphone » Fri Mar 13, 2015 1:14 pm
I recently bought the Zero-Loss FX Loop kit and had it installed in my JCM800 2204, which has not been otherwise modded. I am very happy with the loop, but I've found that some dry signal is always present no matter what. For instance, when I set a delay to 100% wet in the loop, some dry signal still leaks in. This is not because of the effects I'm using (I have confirmed with this with multiple experiments).
Is there anything I can do to change this? It's a great loop, but I would like to be able to get 100% for certain sounds.
