Double check me. 1987x Metro Loop install
Posted: Mon Jun 25, 2018 8:43 pm
Used to work in electronic repair years ago but it's been a while and I had no experience with amplifiers. That said I think installing this should not be a problem.
Getting ready to install the metro loop into my 1987x. It is a 90's model that did not come with a loop installed.
After reading the instructions and going over the schematic, I have mapped out the points where I believe this will be installed and was hoping someone here could double check what I am getting ready to do.
I have attached a picture of the board along with notes on where I believe everything should be connected. If one of you knowledgeable folks could just double check me it would be greatly appreciated.
My biggest concern is the long wire run I would need to power the board. The PI supply node seems pretty far on the 1987x pub if I have mapped it out correctly.
Also, I am going to have to buy the proper drill bit to drill the wholes for this. Anyone have any recommendations?
https://imgur.com/a/qBkxh2c
