bennyx sounds awesome!
Hi Guys,
Here is 2 new clips from 2 50w amps i have just modded, 1, is a usual 36 4 st mod, & the other is a 3 st 36 mod.
1, http://soundclick.com/share.cfm?id=13094699
1, http://soundclick.com/share.cfm?id=13094698
Both amps have el34 tubes, speaker g12h30 heritage, mic sm57.
Cheers
Cheers
- CoffeeTones
They sound very similar. I hear you throwing your little twists to the playing
Cheers Duane, thanks for your feedbackCoffeeTones wrote:They sound very similar. I hear you throwing your little twists to the playing
Nice comparison clips there. I think the 3 stage version sounds looser and could do with some compression. I guess the added stage isn't there to round off the other side of the wave form. Maybe some diodes or LED's could be used instead, or some different ones if you're already using them.
Cheers BRMSlash, thanks for your feedbackBRMSlash wrote:Nice comparison clips there. I think the 3 stage version sounds looser and could do with some compression. I guess the added stage isn't there to round off the other side of the wave form. Maybe some diodes or LED's could be used instead, or some different ones if you're already using them.
I had the MV at 2 so that's maybe why the amp sounds a bit loose, i haven't used any diodes in this mod, i always find that they give a bit of a buzz tone.
Cheers
I tried 6n4 preamp tubes in my #36 and they sound great! Some pics of my tubes: http://1drv.ms/1PxfPb4
Hi Duke,
Sound really Amazing ! Is it possible to have only your records without the original track ?
Thanks !
Thanks !
dukeamps wrote:Hi Guys,
Cheers
incredible_max wrote:Hi Duke,
Thanks !
Cheers
Cheers
36 4st clip
http://soundclick.com/share.cfm?id=13098725
36 3st clip
http://soundclick.com/share.cfm?id=13098731
also here is a clip from my 75 jmp 100w i have just finished modding with a 3 st mod.
http://soundclick.com/share.cfm?id=13098811
New clip from another jmp 50w i have finished modding with a 3 st mod.
http://soundclick.com/share.cfm?id=13103437
sounds killer as always duke, I assume el34's in that one.
"purple power rules"
rockgod212 wrote:sounds killer as always duke, I assume el34's in that one.
Cheers RG, thanks for your feedback
No this one has 6L6s
Here are some clips of my #36 recorded with Shure Sm57 at bedroom volume. I tried two different couplers and two different bypasses on stage 4. I accidentally deleted one clip.
0.0022uF coupler, 4th stage bypass 2.2uf http://1drv.ms/1DnwioQ
0.0022uF coupler, 4th stage bypass 470nF http://1drv.ms/1Dnwy7e
0.022uF coupler, 4th stage bypass 2.2uf http://1drv.ms/1DnwtjT
I really suck at recording guitars. I used Kjaerhus Classic Reverb Plugin (80's snare preset) on Sweet Child O' mine.
Here are some pics of my recording setup:
http://1drv.ms/1HlTiuj
nice, I have an old 60watt ampeg that I kept the tranny's, no choke. I used a 270ohm resistor I believe. it has 5881's in it, it sounds killer for a modded 3 stager. I run it through 2 black shadows and 2 cheapo celestion 50watt rocket's in a vs412 cab, sounds killer with this cab only, its not quite there with any other cab, go figure, but its a killer practice amp for home use.
dukeamps wrote:rockgod212 wrote:sounds killer as always duke, I assume el34's in that one.
Cheers RG, thanks for your feedback![]()
Good stuff, btw this amp has no CFrockgod212 wrote:nice, I have an old 60watt ampeg that I kept the tranny's, no choke. I used a 270ohm resistor I believe. it has 5881's in it, it sounds killer for a modded 3 stager. I run it through 2 black shadows and 2 cheapo celestion 50watt rocket's in a vs412 cab, sounds killer with this cab only, its not quite there with any other cab, go figure, but its a killer practice amp for home use.![]()
