CoffeeTones
Post by CoffeeTones » Mon Apr 20, 2015 8:56 am
dukeamps wrote:
Good stuff, btw this amp has no CF
:thumbsup:
dukeamps
Post by dukeamps » Tue Apr 21, 2015 1:30 pm
budubum92
Post by budubum92 » Fri Apr 24, 2015 5:55 pm
Prowler wrote:Here are some clips of my #36 recorded with Shure Sm57 at bedroom volume. I tried two different couplers and two different bypasses on stage 4. I accidentally deleted one clip.
0.0022uF coupler, 4th stage bypass 2.2uf http://1drv.ms/1DnwioQ
0.0022uF coupler, 4th stage bypass 470nF http://1drv.ms/1Dnwy7e
0.022uF coupler, 4th stage bypass 2.2uf http://1drv.ms/1DnwtjT
I really suck at recording guitars. I used Kjaerhus Classic Reverb Plugin (80's snare preset) on Sweet Child O' mine.
Here are some pics of my recording setup:
http://1drv.ms/1HlTiuj
this is some nice clips. i see that you are not on axis straight on the dust cup. you are rather on the cone.
whats speakers? did you have master volume mod like PPIMV?
Prowler
Post by Prowler » Fri Apr 24, 2015 10:40 pm
Glad that you like my clips, I got more of them coming soon. I have the PPIMV and it was set at full. Treble and bass were at 6 if I remember. My speakers are Celestion Vintage 30's.
I am going to try the 1n // 470k before the gain pot and 500pF instead of 330pF on the 470K divider and maybe a 47pF to 100pF bright cap on the first gain pot. Any tips how to improve the sound would be appreciated. I try to write down the whole spec later today.
Ok, here is the spec.
No bright cap on either gain pot, a 2.2nF parallel to the 470k before the first gain pot with 220k from wiper to ground, a 330pf cap bypassing the 470k divider. 470 nF bypassing the 1k resistor at stage 4 cathode, .1uF bypassing the stage two 10k cathode, 500pF / 33k tone stack, .1uF presence, 100k NFB resistor 4 ohms tap, .0022uF coupling cap. No bypass on the third stage. Thanks Coffeetones for the spec! :toast:
budubum92
Post by budubum92 » Sat Apr 25, 2015 3:47 am
a tip?
dont try those that youve said. keep what you have in there.
BRMSlash
Post by BRMSlash » Sun Apr 26, 2015 2:04 am
Of those clips I like the 0.0022u, 4th 470nF. However I think you need to shape/boost the treble more with cathode bypass caps and treble peakers and bright cap, but cut the gainy treble with plate bypass caps or bleed to ground caps on 2nd and 3rd stages.
Here's a clip I just did, took out my Shure xlr attenuator as I think it was adding a bit of fizz. I also just started learning Crazy Train so it's pretty rough, but I like the tone.
http://sclk.co/s7sz4v
Prowler
Post by Prowler » Sun Apr 26, 2015 2:27 am
BRMSlash wrote:Of those clips I like the 0.0022u, 4th 470nF. However I think you need to shape/boost the treble more with cathode bypass caps and treble peakers and bright cap, but cut the gainy treble with plate bypass caps or bleed to ground caps on 2nd and 3rd stages.
Sounds awesome BRMSlash! Thanks for the tips!
Of my clips 0.0022u and 4th 470nF is propably my favourite too.
I am going to try plate bypasses again and everything you said above. I have to get more alligator leads and do some kind of treble bleed mod to my guitar as well. There is a long way to go and I do not know when I have a chance to mod my amp again.
BRMSlash
Post by BRMSlash » Sat May 02, 2015 12:07 am
Cheers. Here's another clip but using JJ 6CA7's instead of my usual New Sensor Mullard EL34's. I think I'm liking them better so far. The low end is more controlled and tight, plus they're a bit clearer in the mids, with a bit more chime in the top end. There's less quack too.
http://sclk.co/s7t2o7
Prowler
Post by Prowler » Sat May 02, 2015 12:13 am
BRMSlash wrote:Cheers. Here's another clip but using JJ 6CA7's instead of my usual New Sensor Mullard EL34's. I think I'm liking them better so far. The low end is more controlled and tight, plus they're a bit clearer in the mids, with a bit more chime in the top end. There's less quack too.
Sounds awesome! That has to be the best Slash tone that I have heard. Do not change a thing! I want the spec but I guess it is a secret.
RagnarMarGunn
Post by RagnarMarGunn » Sun May 03, 2015 6:31 pm
Those JJ 6CA7 sure sound great :-)
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
BRMSlash
Post by BRMSlash » Sun May 03, 2015 7:15 pm
Thanks Prowler. The spec is essentially a #34 with an extra stage, lower B+ filtering and a couple of treble bleeds and cathode bypass cap resistors to tame treble and gain. First stage cathode resistor and bypass cap are not typical Marshall, but more vintage. Component choice play a big part.
Cheers RagnarMarGunn. Yeah, the 6ca7's are a nice improvement. I need to replace my strings, so the tone should improve a little once I've done that too.
CoffeeTones
Post by CoffeeTones » Sun May 03, 2015 9:17 pm
BRMSlash wrote: Component choice play a big part.
Yes and Prowler has mostly Mojo / TAD polypropylene capacitors and I believe Vintage 30 speakers.
Prowler
Post by Prowler » Sun May 03, 2015 9:20 pm
Yes
silver_jubilee
Post by silver_jubilee » Tue May 05, 2015 1:52 am
BRMSlash What speakers are you using?
BRMSlash
Post by BRMSlash » Tue May 05, 2015 5:11 am
Celestion Classic Lead 80's
