Model 4140 Club And Country 2x12 combo
MikeO
Post by MikeO » Tue Apr 25, 2017 2:42 am
Does anyone have one of these? The schematic online is really hard to read...
If so, I'd like to know the following:
-tonestack values: it looks like it might be 82k/250pf and a pair of .047uF caps
-phase inverter resistor values: it's really hard to make out
-component values for the boost and bright switch functions
-coupling caps in the output stage: it kinda looks like .022uF but I can't tell
Here's the schematic... maybe someone else can make sense of it:
http://www.thetubestore.com/lib/thetube ... ematic.pdf
I like the sound of these and I was thinking of building a single channel 50w head version without reverb
...and pcb mounted pots. :palm:
Thanks!!
zaphod777
Re: Model 4140 Club And Country 2x12 combo
Post by zaphod777 » Sat May 20, 2017 6:51 pm
I have one.
This version of the schem is higher resolution than most floating around the net.
https://www.google.com/url?sa=t&rct=j&q ... NA&cad=rja
ALOT easier to make out the values.
