questions about star grounding in a 2203
Max888
Post by Max888 » Mon Jul 17, 2017 8:33 pm
Hi guys,
I would like to implement star grounding in a 2203, to make it as quiet as possible. An article by Randall Aiken suggests that the secondary CT of the PT will make a good central grounding point.
Now I see that on my Marshall this is connected between the two mains filter caps, and not to ground.
Can I move the PT CT wire to a ground lug or will things go bang then?
Littlewyan
Re: questions about star grounding in a 2203
Post by Littlewyan » Wed Aug 02, 2017 8:29 am
No you can't ground that wire. Are those mains filter caps in series by any chance? With the PT CT connected to positive on one and negative on the other?
