JTM45 Reissue cant be biased
SlyStrat
Post by SlyStrat » Sat Dec 16, 2017 3:02 pm
Cant bias tubes to correct number.
Which resistor needs to change and do I ho up or down?
Re: JTM45 Reissue cant be biased
Post by neikeel » Sat Dec 16, 2017 6:16 pm
On the board there is a resistor in series with the bias pot (47k or 56k typically).
As they bias voltage is negative if you want a more negative voltage you need to raise the value of the resistor (shunt less voltage to ground) or visa versa.
