18w plexi (2203 preamp)
Share your YouTube videos or upload your mp3's.
menthal
Post by menthal » Sat Oct 09, 2010 5:18 am
I made a small 18w plexi(channels in series like the 2203 preamp). It's only three gain-stages though, I removed the cathode follower.
Recorded with a SM57 and Vintage 30's.
http://www.netmusicians.org/files/2-18watt.mp3" onclick="window.open(this.href);return false; (recorded with an attenuator).
http://www.netmusicians.org/files/77-18watt-noaut.mp3" onclick="window.open(this.href);return false; (beefier filter caps and bass not at max)
The bass is a bit flubby, but other than that I think it sounds ok.
Next time I'll not max the bass dial. :)
Dunkmop
Re: 18w plexi (2203 preamp)
Post by Dunkmop » Thu Oct 21, 2010 3:51 pm
I like it. Sounds good.
What guitar/pups you using on the first attenuated clip?
Metroamp 12000
EVH 4X12 + Marshall 1960AX 6402
Gibson Les Paul
VH RWB Strat in Progress
menthal
Post by menthal » Fri Oct 22, 2010 5:04 am
Dunkmop wrote:I like it. Sounds good.
Cool.
The guitar is a Les Paul clone(made of alder) and the pickups are a combo of Duncan '59/Distortion.
Dunkmop
Post by Dunkmop » Fri Oct 22, 2010 7:03 am
It almost sounds like a single coil sound as you move up the board. Is the pickup tapped?
Metroamp 12000
Gibson Les Paul
menthal
Post by menthal » Fri Oct 22, 2010 7:13 am
Dunkmop wrote:It almost sounds like a single coil sound as you move up the board. Is the pickup tapped?
No coil tap.
Dunkmop
Post by Dunkmop » Fri Oct 22, 2010 3:50 pm
Is the neck pup a distortion or 59? sounds good on the highs, like you said a little flabby on the bass. If you can sort out the lower end = lovely sound amp all round, including wattage.
Metroamp 12000
Gibson Les Paul
menthal
Post by menthal » Fri Oct 22, 2010 4:09 pm
Dunkmop wrote:Is the neck pup a distortion or 59? sounds good on the highs, like you said a little flabby on the bass. If you can sort out the lower end = lovely sound amp all round, including wattage.
Neck pup is a '59.
Yeah it's a cool little amp, gonna add a choke and beef up the filter caps, that should tighten the bass.
cyprusx
Post by cyprusx » Tue Dec 14, 2010 8:37 pm
Hi Menthal,
How is your progress with this build coming along? I decided to build this based on your schematic that you had posted on another site. Not sure if you have made any updates which you would want to share. I am nearing completion and only have to wire the board in and decide if I am going SS rect or use an EZ81.
Thanks!
Rick
crustodd
Post by crustodd » Tue Mar 01, 2011 5:44 pm
WOW! I think that sounds GREAT! A little gritty, but very MEATY. How much you got in to the build?
