45-100 tone controls
i made an interesting observation about my super amp.....
the tone controls,at least to me, seem way more "active",or have a "wider"
range, than my regular 1959's!
it's the same tone circuit, right?? anyone else experience this?
- HTH
Re: 45-100 tone controls
your SLP will have a 33k slope resistor and 470pF treble cap
the 45/100 will have a 56k slope resistor and 250pF treble cap
as such, I'd expect the 45/100 to have more responsive tone controls.
yeah,I don't know.....
all my SL's have the 56k/250
Maybe due to the higher voltage on V2 in a JTM45/100?
- novosibir
"regular" 1959's do have 33K/500p in the tone stack.lifer wrote:... than my regular 1959's!
then they aren't "regular", but tweaked.lifer wrote:all my SL's have the 56k/250
Larry
perhaps the reason is that the jtm is cleaner wheras the 1959 is more distorted (so that the poweramp shapes the eq more)?
yes......you are correct!! that's the way i should have stated it.novosibir wrote:"regular" 1959's do have 33K/500p in the tone stack.lifer wrote:... than my regular 1959's!
Larry
by "regular", i meant EL34 powered,etc.
- Flames1950
In a split-cathode Lead, you've also already shaped the EQ balance to a degree, with the choices of cathode resistor and cap on the Bright channel (usually the 2.7K/.68uF combo) and the coupling cap into the next stage (less bass right off if you're running the .0022uF coupling cap.)
yep-- 10-4!
i suppose the "mixer" values have an affect also. put 'em all together and it's
a bit of a different beast.
