Page 1 of 2
45/100 bill of materials
Posted: Mon Apr 28, 2008 5:02 pm
by VelvetGeorge
Here's the parts list (work in progress) for the 45/100 chassis.
VG
Posted: Tue Jun 10, 2008 8:01 am
by Roe
does anyone have a complete parts list?
Posted: Tue Jun 10, 2008 10:57 am
by gutpile
I took a stab awhile back... I think this is just about everything....
'66 JTM45/100 Bill of Materials
(1) DRAKE 1204-43 POWER TRANSFORMER
(1) DRAKE 1202-84 OUTPUT TRANSFORMER
(1) DRAKE 352-114 CHOKE
(1) HEADCASE- SMALL GOLD VENTS, BLACK
Wire Package - incl 18ga and 22ga wire & insulation
Shrink Tubing
(6) Marshall Knobs
(6) Large Bolts - OT and Choke
(1) Impedance Selector
(9) Medium Bolts - Power Tubes & Fuse Holder
(6) Small Bolts - Preamp Tubes
(1) '66 LAYOUT ALUMINUM CHASSIS
(4) METRIC CAGE NUT
(4) 6M X 30 MOUNTING BOLT AND WASHER
(1) PLEXI FRONT PANEL- GOLD
(1) MAIN BOARD- RED SWIRL 10 1/8" X 3"
(6) BOARD MOUNTING BOLTS- 4-40 1 1/4" BRASS
(1) CAPACITOR BOARD- RED SWIRL 6 3/8" X 4 1/8"
(1) REAR PANEL- WHITE
(6) Cliff style Jacks
(1) 470 - 1/2w resistor
(2) 820 - 1/2w resistor
(2) 1.5K - 1/2w resistor
(1) 10K - 1/2w resistor
(1) 15K - 1/2w resistor
(1) 27K - 1/2w resistor
(1) 56K - 1/2w resistor
(5) 68K - 1/2w resistor
(1) 82K - 1/2w resistor
(5) 100K - 1/2w resistor
(3) 220K - 1/2w resistor
(2) 270K - 1/2w resistor
(4) 1M - 1/2w resistor
(1) 8.2K - 1w resistor
(1) 10K - 1w resistor
(1) 56K NOS AB
(1) 180K NOS AB
(7) 32u Filter caps
(1) 20u Cap for the Main Board
(4) 1K 5W Tube Resistors
(1) Bulgin Cord/ socket
(1) Fuse Holder
(2) power/ standby switches
(1) indicator lamp
(1) BC 250uf 25 Volt Capacitor
(2) BC 10uf 250 Volt Capacitor
(1) 556pf cap
(1) 250pf cap
(1) 47pf cap
(4) 1ohm 2W Metal Oxide
(3) 1M-A Pots
(1) 5K-L Pot
(1) 25K-L Pot
(1) 250K-L Pot
(1) 8.2K 2W Metal Oxide
(1) 10K 2W Metal Oxide
(1) .05u cap (filter board)
(2)1K resistors
(1) 100pf cap for Bright Cap
(7) Diodes
(4) KT66 Power Tubes
(3) 12ax7 Preamp Tubes
Posted: Wed Jun 11, 2008 3:14 am
by Roe
great!
Posted: Wed Jun 11, 2008 12:02 pm
by gutpile
forgot grommets for the OT & Choke...
Posted: Tue Jul 08, 2008 2:14 pm
by Roe
here's my part list (sans trannies):
1 x Carbon Film 10K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
1 x Carbon Film 15K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
2 x Metal Oxide 8.2K 2 Watt () = $1.00
25 x Fuse .5 Amp Fast Acting () = $12.50
1 x Marshall 6" Script Logo () = $15.00
1 x 66 Era 45/100 Bare Bones Chassis Kit (45/100BBKIT) = $575.00
Choke None + $0.00
Components None + $0.00
Head Case Black with Vox style vents + $350.00
Output Transformer None + $0.00
Power Transformer None + $0.00
3 x Ceramic Disk 5600pf @ 1000V () = $3.00
6 x Xicon 1K 5 Watt Resistor () = $3.00
1 x Amphenol 8 Pin Octal Socket () = $8.50
1 x F&T Dual 33uf @ 450V Axial () = $12.00
1 x Carbon Film 5.6K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
7 x Diode 1000PIV 1A () = $1.05
1 x Plexi, JTM 45 Bias Adjustment Kit () = $2.00
1 x Silver Mica 100pf @ 500V () = $0.75
1 x Capacitor-Ceramic Disk 100pf () = $0.25
2 x Allen Bradley NOS 1/2 watt CC 1K () = $2.00
2 x Metal Oxide 10K 2 Watt () = $1.00
1 x Sozo "Mustard Type" .047uf 400V () = $2.10
1 x CTS 250K Audio () = $4.50
1 x CTS 25K Linear () = $4.50
3 x CTS 1M Audio () = $13.50
1 x CTS 5K Linear () = $4.50
4 x Metal Oxide 1 Ohm 1 Watt () = $2.00
1 x Silver Mica 47pf @ 500V () = $0.75
2 x Silver Mica 250pf @ 500V () = $2.00
1 x Capacitor-Ceramic Disk 560pf () = $0.50
2 x Silver Mica 500pf @ 500V () = $2.50
3 x 9 Pin Socket with Shield () = $13.50
1 x Flush Mount Fuse Holder () = $2.00
1 x TAD 16uf @ 475V Axial () = $3.00
2 x Xicon 10uf @ 160V () = $2.40
2 x Chrome Ring for Toggle Switches () = $8.00
1 x Amber 120V Neon Indicator () = $9.00
2 x Toggle Switch - DP/ST () = $18.00
1 x Triple Pole, Three Position Switch for Voltage Option Switching () = $26.00
1 x Fuse Holder () = $2.85
1 x Metroamp 12 Foot IEC Power Cord () = $7.00
1 x Strain Relief () = $0.40
6 x Marshall Cliff Old Style In/Out Jack () = $15.00
1 x Brass Mounting Bolt Small Qty 12 () = $1.50
1 x Brass Mounting Bolt Medium Qty 12 () = $2.00
1 x Marshall Impedance Selector Switch () = $28.00
1 x Brass Mounting Bolt Large Qty 12 () = $4.50
1 x Marshall Set Screw Knob Qty 8 () = $15.00
1 x Wire- Full Amp Kit () = $16.00
1 x Allen Bradley NOS 1/2 watt CC 470k () = $1.00
1 x Allen Bradley NOS 1/2 watt CC 27k () = $1.00
2 x Allen Bradley NOS 1/2 watt CC 270k () = $2.00
4 x Allen Bradley NOS 1/2 watt CC 1M () = $4.00
1 x Carbon Film 1M Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
1 x Carbon Film 82K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
1 x Carbon Film 100K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
1 x Carbon Film 150K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
1 x Carbon Film 47K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
1 x Carbon Film 220K Ohm Qty 10 () = $1.00
Quantity 10 + $0.00
Posted: Tue Jul 08, 2008 2:48 pm
by thousandshirts
Roe wrote:here's my part list (sans trannies):
Already have three?
Posted: Tue Jul 08, 2008 3:19 pm
by Roe
oppsi - a mistake
Posted: Tue Jul 08, 2008 8:12 pm
by thousandshirts
Roe wrote:oppsi - a mistake
That's cool, I just didn't want to see you opening your package there in Europe, after a long and expensive travel from America, being three power tube sockets short of a quartet, and then another order to match the three black power sockets. . . More waiting, more shipping. . .
The MetroAmp shopping cart system is pretty good but sometimes is a bit clunky to use. Like after adding something to your 'cart' it would be nice to go right back to the last things that you were looking at, but you need to go to the menu system all over again -- the back button on some browsers screws up the cart contents -- so yeah.
I liked the black amphenol sockets, so I found some black NOS 9 pin sockets for the pres. Strangely enough those were local. . .which is the first time EVER for anything local. . .weird.
Should be an awesome amp, can't wait to get started building. . .
Posted: Fri Aug 22, 2008 3:04 pm
by Roe
It seems that bracket frame and ground logs should be added to the above
Posted: Wed Aug 27, 2008 4:49 pm
by Dom
Regarding the standby and power toggle switches:
order Carling switches.
The normal (now) stock Marshall switch is too big and they will interfere with the filter caps board.
Posted: Thu Sep 04, 2008 9:31 am
by Roe
shouldn't a voltage selector be added to the above?
Posted: Thu Sep 04, 2008 8:14 pm
by gutpile
I guess.... If you are getting technical about it...
good catch!
Mike
Re: 45/100 bill of materials
Posted: Sun Dec 21, 2008 7:59 pm
by Doug H
what tubes is the output transformer spec'd for?
Posted: Sun Dec 21, 2008 10:00 pm
by thousandshirts
Doug H wrote:what tubes is the output transformer spec'd for?
KT66
