Dear forum members,
the following is a full parts list of all nos and modern parts for my upcoming 45/100 build. I'm still not sure about who'll put it together for me, but after some thought my best bet would be either a tech within US or my local tech in Latvia (mainly because of the cost involved in extra shipping to other countries, etc.)
Meanwhile i'm getting ready to order the parts from Metroamp store and so this is the best moment to check everything. Any suggestions and corrections are greatly appreciated (especially considering the size of this thing!)
I'm especially uncertain about the hardware - the bolts, screws and about the wires (the needed length and type for a 45/100) - i'm not sure if i have everything there. And the last thing i want, when opening the metro package at the other side of the pond, is screw myself because of some screws
Upfront i'm not sure which choke to use - from Marstran or Metro, which fuses shall i get, i also have no clue if the Marstran trannies will fit the Metro chassis (and mounting bracket, which i presume fits the chassis) without much hassle? I've read that for alu chassis one has to go with amphenol sockets for best fit - is this true? And what i just couldn't find on the site was the following (according to the 100w kit manual these should also be needed for a 45/100):
5 1/2” Grommets
1 3/8” Grommet
8” 1/8” Shrink tubing
12 3” Cable Ties
I'm not sure if this is included in the bare bones kit.
Please let me know if you spot anything that could give the tech "compatibility" issues (fit-wise), if i have missed apart, especially the small things - wires, screws, nuts, etc. or if you have any advice on a wiser choice.
For now i have also listed some AB cc's in all values to have spares for the pihers, just in case. And if everything goes wrong with the NOS stuff, i also ordered the Marshall board component kit, which should cover any need for a modern component. I'll probably also order some parts of different values, like the electrolytics and cc's, just in case if something has to be tweaked.
Thanks a lot in advance for your help guys!
So here's the full list:
NOS COMPONENTS:
After an almost two months long obsessive hunt for the 66/67 era correct parts, i have gathered the following NOS stuff for the build.
Resistors:
Full set of piher 1/2w resistors (except 1x 15k, 1x 33k (for Dickinson spec amp))
3x 10k 2w AB cc’s
3x 8.2k 2w AB cc’s
(Also some iskras as spares in many values)
RS mica caps:
1x 47pF RS mica
1x 100pF RS mica (old arced RS logo)
1x 250pF RS mica (old arced RS logo)
1x 500pF RS mica (old arced RS logo)
1x 560pF RS mica (old arced RS logo)
(also substitutes from Lemco, SRC and RMC ceramics in these values)
Philips Mustards:
4x 0.10uF (66 date codes)
5x 0.022uF (66 date codes)
Other components:
32+32uF Erie filter cap
1x 250uF@25v Wima
4x 1k 5w RS grey dog bones (old arced RS logo)
1x Erie Duolectron 0.05uF snubber cap
1x Mullard BY100 diode
1x Belling Lee Fuse Holder
Some of these are still on the way, but, if they survive the volcano dust-clouds, should be soon with me.
Thanks to Alberto, Aleksei, Ampmaker, Banks amps, BigSmythe, BrianH, Claude, Dirty Decibels, Frenchie, John, Kevin, Marc, MyFoot, Neil, Retro Lab, S.Marshall, Sparky, Wrea for helping finding some of these hard to get parts! And thanks for standing my nagging about these parts and finding your time for this! And special thanks to Neil for his never ending patience with my dumb questions!
I have a lot of NOS stuff, including pihers, iskras, old micas in correct or close values, some RS electrolytics in values i can’t use for a 45/100 (including a supposedly fine working 50uF@350v) – all of which i would be willing to trade for a 15k 1/2w, 33k 1/2w piher and Hunts electrolytics in 8uF or 10uF @ 150v. Please PM me, if you have any of these parts and are after some other NOS stuff. After this build i will sell some of the spares to get them to people who’re after these (though i probably will keep some parts for one more build which might happen in the far future).
I will be home in two weeks and then i’ll post a picture of this lovely bunch
PARTS FROM OTHER SUPPLIERS:
Marstran 1202-84, 1204-43 transformers, uncertain which choke to buy though.
45/100 boards from BrianH
45/100 (JTM-45) Face plate from Ceriatone
A set of castelco black bat switches
A set of 45/100 decals
10x 33uF@450v RIFA’s
4x Valve Art KT66's from AES (as they seem to be out of stock on the metroamp store site)
METROAMP STORE:
Head case, chassis, face plates:
Metroamp 45/100 head case
1x 66 Era 45/100 Bare Bones Chassis Kit:
45/100 aluminum chassis
Front and rear face plates
Chassis and turrets mounting hardware
PT Mounting Bracket - Plexi Replica (i'm not sure if it will fit the Marstran tranny?)
Components:
Marshall Board Components Kit:
2 watt metal oxide:
1x 8.2k
1x 27k
1x 47k
2x 820
2x 100k
3x 10k
1 watt metal film:
4x 1 ohm 5% bias resistors
1 watt carbon film:
1x 470
1x 1k
1x 2.7k
1x 10k
1x 15k
1x 27k
1x 33k
1x 47k
1x 56k
1x 82k
1x 150k
2x 820
2x 270k
2x 470k
3x 220k
4x 1.5k
4x 5.6k
4x 100k
4x 1m
5x 68k
Silver mica:
1x 47pf
1x 100pf
1x 250pf
3x 500pf
Diodes:
5x 1n4007
Bias pots:
1x 25k horizontal mount
1x 25k vertical mount
Electrolytics:
1x 250uF @ 25V
1x 330uF @ 25V
2x 10uFf @ 150V
1x Allen Bradley NOS Resistor Kit for JTM 45
1x 27k
1x 56k
2x 820
2x 100k
2x 270k
2x 1m
4x 68k
Additional Allen Bradley NOS 1/2w resistors:
2x 47K
2x 27K
2x 10K
1x 15K
1x 150K
1x 2.7K
2x 270K
2x 33K
2x 56K
3x 100K
2x 470K
2x 220K
2x 82K
2x 820
2x 470
4x 1M
Electrolytics:
1x F&T Dual 33uf @ 450V Axial
1x TAD 16uf @ 475V Axial
1x BC 330uf 25 Volt Capacitor
1x BC 220µf 25 Volt Capacitor
2x BC 10µf 250 Volt Capacitor
Other components:
7x Metal Case Diodes
4x Welwyn 1k 7 Watt resistors
1x Plexi, JTM 45 Bias Adjustment Kit
25k horizontal mount 25K pot
68k 1 watt carbon film resistor
Tube Sockets:
4x Amphenol 8 Pin Octal Socket
3x 9 Pin Socket with Shield
Pots, switches, jacks, fuse holders:
1x Alpha Plexi Pot Set
1x Marshall Set Screw Knob Qty 8
6x Lock Washer for Pots
6x Marshall Cliff Old Style In/Out Jack
1x Marshall Impedance Selector Switch
1x Marshall Modern Voltage Selector
1x Flush Mount Fuse Holder
2x Fuse Holder
5x Fuse 3 Amp Fast Acting
1x Bulgin Mini Plug and Socket Set
1x AC socket IEC
1x Marshall Indicator 6VAC
1x Metric Spring Clip for Marshall 6V Lamp
1x #47 Bulb 6.3VAC
Wire:
1x Wire- Full Amp Kit
10” blue 22 gauge 600V
10” yellow 22 gauge 600V
10” white 22 gauge 600V
10” brown 22 gauge 600V
10” orange 22 gauge 600V
10” purple 22 gauge 600V
10” green 22 gauge 600V
15” red and black 22 gauge 600V
4” 22 gauge buss wire with black insulation
4” 18 gauge buss wire
15x Metroamp Pink Wire
8x 18 Gauge Insulating Sleeving
Hardware:
1x Radio Spares Grey Plexi Feet Qty 4
1x Marshall Chassis Screw Qty 4
1x Metric Cage Nut Qty 4
1x Circuit Board Mounting Bolts Qty 6
1x Brass Mounting Bolt Small Qty 12
3x Brass Mounting Bolt Medium Qty 12
1x Brass Mounting Bolt Large Qty 12
1x Ground Lug 2 Holes Qty 12
1x Ground Lug Qty 12
Accessories:
1x Marshall 6" Gold script logo
1x Metroamp "Y" cable
Doublechecking NOS and modern parts list for my JTM 45/100
- VintageCharlie
- frank9310
Re: Doublechecking NOS and modern parts list for my JTM 45/100
What's the cost of all the stuff you can get here? Just wondering if it makes more sense to order one from the plexireplica site...
Most people are about as happy as they make their minds up to be...~Abe Lincoln
- VintageCharlie
If you mean assembled Metropoulos amps (from plexireplicas site) and particularly the 45/100 with the mustards and cc's, then there is of course a big difference in the price - but then again - the plexi replicas are assembled by George himself, they have a good warranty and it has, for example, the block end chassis, etc. - that you can't get anywhere else - so it's a more than a justified difference. I just don't have the funds for it and shipping, taxes, VAT to Europe would drive the price into astronomical heights. If i had the money i think i'd go with an amp built by George himself. But, on the other side, i have now the opportunity to put even more NOS original parts in the amp and get something very special, which hopefully will also turn out to be a fantastic amp. I can pm you about the approximate price of the modern parts for the build if you wish, but i'd say it's a bit more than for the 100w kits, not by much, actually. A set of original mustards in correct values can be had for about 150$ and a full set of AB cc's might be about 30$.
Regards,
VintageCharlie
Regards,
VintageCharlie
see comments aboveVintageCharlie wrote:Dear forum members,
5 1/2” Grommets
1 3/8” Grommet
12 3” Cable Ties
NOS COMPONENTS:
Resistors:
3x 10k 2w AB cc’s
3x 8.2k 2w AB cc’s. I wouldnt use CCs in the power supply personally
RS mica caps:
1x 47pF RS mica
1x 250pF RS mica (old arced RS logo) personally I like 270pf
Philips Mustards:
Other components:
1x 250uF@25v Wima
1x Mullard BY100 diode better with uf4007 for stable bias
Marstran 1202-84, 1204-43 transformers, uncertain which choke to buy though. I recommend the marstran c1999
METROAMP STORE:
Components:
2 watt metal oxide:
1x 8.2k
1x 27k why this - dont use it for NFB
1x 47k you don't need this do you?
2x 820 CC would be better
2x 100k unnecessary
3x 10k
1 watt metal film:
1 watt carbon film:
1x 470
1x 1k
1x 2.7k
1x 10k
1x 15k
1x 27k
1x 33k
1x 47k
1x 56k
1x 82k
1x 150k
2x 820 should be CC
2x 270k
2x 470k not needed for 66 amp
3x 220k
4x 1.5k
4x 5.6k
4x 100k
4x 1m
5x 68k
Silver mica: not really needed when you have nos
1x 47pf
1x 100pf
1x 250pf
3x 500pf
Diodes:
5x 1n4007 uf4007 is better
Bias pots:
Electrolytics:
1x 250uF @ 25V
1x 330uF @ 25V
2x 10uFf @ 150V
1x 27k
1x 56k
2x 820
2x 100k
2x 270k
2x 1m
4x 68k
2x 47K
2x 27K
2x 10K
1x 15K
1x 150K
1x 2.7K
2x 270K
2x 33K
2x 56K
3x 100K
2x 470K
2x 220K
2x 82K
2x 820
2x 470
4x 1M
Electrolytics:
Other components:
Tube Sockets:
2x Fuse Holder
1x AC socket IEC
1x #47 Bulb 6.3VAC
Wire:
1x Wire- Full Amp Kit not sure you need the other stuff - see below
Hardware:
Accessories:
- VintageCharlie
Thank you very much for taking your time for this Roe!
If everything goes well, i shouldn't need any of the modern components on the boards, except the rifas, as i have nos parts for that - i'm just ordering also the modern components, as they are cheap compared to the total of the order and they are supposed to be as a backup for the case something goes wrong with some of the nos goodies. There are also some values that shouldn't be needed, but it's because they come in a kit.
Thanks a lot for the recommendations too.
Oh, i'm only buying the full amp wire kit and the extra pink wire - i just listed all the wire colors and lengths that are included in the kit.
What do you say about the fancy metal case diodes? - is there any reason to choose the uf4007 over these too?
Thanks again!
Regards,
VintageCharlie
Thanks again!
Regards,
VintageCharlie
the uf4007s will make for a quieter amp and reduce the need for a snubber cap (the .047 in this circuit). also, I think the uf4007s sound a tad better than n4007s
