Authentic JTM 45/100 build diary. Clips added.
- VintageCharlie
Re: Authentic JTM 45/100 build diary. Clips added.
I used MixIR - a plugin from redwirez,m which allows you to easily mix the IR's together. Up to 24 simultaneously if you wish to do so You can adjust on the fly how much you mix in each of them - a great tool. Yes, reverb was altiverb, but i accidentaly saved changes to the file and i overwrote the previous altiverb settings that i used on that track. But, if i'm not mistaken, it was the preset you sent me some time ago. It is a good preset, but a bit too bassy, which tends to clip the output of cubase, which in turn makes lowering of the output volume necessary. Btw. i think you should post the clip you did with your SL, transducer and altiverb - it was the best approximation of the BoG tone i have heard on the net (probably due to the way how close the room acoustics were dialed in). You can't achieve this with analog stuff in an appartment - it would be a very interesting pointer towards the digital recording alternatives, which are not inferior, if done right.
I will have to re-read your mail and i have to take a look into my stash. I'll let you know if i have anything you need in the next couple of days.
- Xplorer
nice ! new cool softs ! i'll try it, you had some amazing results.
hey, a pro effects and amp builder told me about another cab sim, after we talked about redwirez, he said that he had some great results with it. i didn't try it yet.
http://www.two-notes.com/en/software/torpedo-pi-101/" onclick="window.open(this.href);return false;
thanks for the compliment ! but i think that it was so far from BOG. but i have some big expectations from the jtm, and some new setups. i set altiverb differently now, and it doesn't clip like this.
i heard it again and i prefer to post something of a better quality later. it really clips so much. also it sounds more isle of whight than BOG i think.
ok, let me know when you can for the rest, thank you.
- Xplorer
Hi Karlis ! as i'm about to prepare my buid , i wondered how to wire the amp with the larry grounding. The best that would help me over everything i've seen or read, would be a layout if you have any that you did for your build ?
Thanks !
Thanks !
- VintageCharlie
While working on my recording techniques, i recorded a small clip to demo the tones that come out of this beast. Bright volume 10, normal volume 0, all controls, including bass! (a revalation to me), on 5-6 on the dial, Mids on 7.
- JTM45-100 ALL RIGHT NOW.mp3
- (451.72 KiB) Downloaded 248 times
- Strat78
Simply a haunting tone there, wonderful!
- vanhalen5150
- VintageCharlie
Just out of curiosity i recorded the same cab and mic setting with my non tremolo Marshall 18w clone. It was on the lower gain input and the volume was maxed, tone on 0 from 10 (i don't like it's tone very much above 5 on the tone control). It's an ok sound on it's own, but to me it sounds simply wimpy compared to the big bottle amps. I suppose a JTM-45 with 6v6's would be a better idea for lower wattage Marshall tones.
- 18w ALL RIGHT NOW.mp3
- (271.68 KiB) Downloaded 186 times
- bill bokey
It sounds really dark, how does it sound with the tone on 5 ?
- VintageCharlie
The 45/100 clip is also on the dark side, as the mic is set in a way that does accentuate the lows and mids.
Here is the 18w with tone on 5. Above that it accentuates some high mid frequencies that sound to me like something is cooking on a frying pan - i hate what ever frequency that is (except if it is in the kitchen).
The 18w is simply shrill when driven hard, at least to my taste. It has a nice clean and semi clean with a strat though.
- 18w ALL RIGHT NOW tone on 5.mp3
- (258.48 KiB) Downloaded 183 times
- bill bokey
Thanks, I much prefer it that way but it still does not sound as good as your 45/100 clip. Probably too much low mids for my liking but the 45/100 has more clarity but like you said the top end is really smooth.
- VintageCharlie
Yes, the 45/100 is actually a surprsingly bright amp. Not as bright as the later models. But miced up in this darkish setting it still retains all the clarity, detail and texture one could ask for. There is simply much more going on frequency wise i suppose - not just in the bass and low mids section.
- Xplorer
the 18w sounds very good but the 45/100 beats them all
what if you lower the basse settings a bit ? is it becoming too harsh or something ?
and what about the same clip on the 45/100 ( and a bit of acdc please ! problem child, hells bells, shook me all night long .... ) with a blumlein arrangement ?
- VintageCharlie
The Se R1's in Blumlein config sound great, but i have to figure out, if it is possible to get the proper punch and raw power feeling out of just the Blumlein pair. It's extremely hard to do if you're recording in the same room as the amp.
- VintageCharlie
oh, and on the bass setting - no it does not become harsh in any way, but when bass is on about 5 it gives the tone that punch and impact, that power - it does not just add bass, it changes the whole tonal picture. I just saw a clip by Solodallas where Phil says that Angus used to dial in the bass also at about 5 on his JTM's - so this explains why it gets that ac/dc vibe easily with the bass quite a bit up. Will do more experimentation when i have the time, but these results made me really even more happy with the 45/100. Still looking forward to the 69 SL build though
Pandora Jewelry Official Site
Fitflops
GGDB Sneaker
Jordan Shoes Retro
Pandora Ring
Jordan 11
Jordan Sneakers
Jordans Sneakers
Retro Jordan
Air Jordan 6
Jordan 11's
Jordans 4
Jordan 12 Retro
Air Jordan
Jordan Retro
Jordan 11
Yeezy
Pandora Bracelet
Adidas Yeezy
Nike Air Max 90 Ultra
Ferragamo Outlet
Yeezys
Nike Air Max 270
Golden Goose Sneakers
James Harden shoes
Ferragamo
Nike Outlet
Balenciaga Triple S
Jordan 12
Air Max 95
Jordan Shoes
Kyrie Shoes
Red Jordan 11
Air Force One Shoes
NMD R1
Yeezys
Yeezys
Jordan Retro 11 Mens
Jordan 11's
Retro Jordans
Air Max
Pandora
ECCO Shoes
Air Jordan 3 Retro
Pandora
Pandora Charms
Nike Shoes
Nike Sale
Moncler
Air Jordan Retro 6
Hermes Birkin Bag
Golden Gooses For Sale
Nike Outlet
Nike Outlet
Air Jordan 4 Retro
Pandora Jewelry
Jordan 4
Air Jordan Shoes
Air Jordan 4 Retro
Nike Outlet Store Online
Air Jordan 5
Nike Air Max 2018
Men Moncler Vest
Nike Factory
Air Jordan
Nike Shoes Women
Win Like 96
Valentino Shoes
Balenciaga Sneakers
Jordan Retro
Shoes GGDB
Jordans 5
Moncler Jackets
Cheap Jordan Shoes
Jordan 12 Retro
Red Bottoms Louboutin
Air Jordans
Golden Goose Shoes Men
Moncler Outlet
Nike Website
Soccer Shoes
Nike Snkrs Website
Golden Goose Mid Stars
Jordan 11
New Nike Shoes
Nike Shoes For Women
Adidas NMD
Christian Louboutin shoes
Jordan Retro 11
James Harden Shoes
Air Jordan 10
Golden Goose Outlet
Cheap Jordans
Pandora Ring
Nike Air Max 98 Cone
Jordan 1
Jordan 6 Rings
Pandora Canada
Yeezy Shoes
Golden Goose Outlet
Fjallraven Kanken Backpack
Jordans 13
Pandora Jewelry
Jordan 14
Jordan 3s
Nike Huarache
Moncler Jackets
GGDB Sneakers
Pandora Jewelry
Moncler Sale
Pandora Charms
Red Bottom Shoes
Pandora Canada
Jordan Sneakers
Nike Shoes Outlet Store Online Shopping
Golden Goose Sneakers Sale
Jordan 9
New Jordans
Jordan Retro 5
Jordan 11
Jordan 11
Nike Mens Shoes
Air Jordan Sneakers
Moncler Outlet Online
Jordan 11
Jordan 8
Moncler Outlet Store
Louboutin Shoes
Moncler Store
Air Jordan 12
New Jordans 2018
Fitflop Shoes
Nike Air Force 1
Fitflops
GGDB Sneaker
Jordan Shoes Retro
Pandora Ring
Jordan 11
Jordan Sneakers
Jordans Sneakers
Retro Jordan
Air Jordan 6
Jordan 11's
Jordans 4
Jordan 12 Retro
Air Jordan
Jordan Retro
Jordan 11
Yeezy
Pandora Bracelet
Adidas Yeezy
Ferragamo Outlet
Yeezys
Nike Air Max 270
James Harden shoes
Ferragamo
Nike Outlet
Balenciaga Triple S
Jordan 12
Air Max 95
Jordan Shoes
Kyrie Shoes
Red Jordan 11
Air Force One Shoes
NMD R1
Yeezys
Yeezys
Jordan 11's
Retro Jordans
Air Max
Pandora
ECCO Shoes
Air Jordan 3 Retro
Pandora
Pandora Charms
Nike Shoes
Nike Sale
Moncler
Air Jordan Retro 6
Hermes Birkin Bag
Nike Outlet
Nike Outlet
Air Jordan 4 Retro
Pandora Jewelry
Jordan 4
Air Jordan Shoes
Air Jordan 4 Retro
Air Jordan 5
Nike Air Max 2018
Men Moncler Vest
Nike Factory
Air Jordan
Nike Shoes Women
Win Like 96
Valentino Shoes
Balenciaga Sneakers
Jordan Retro
Shoes GGDB
Jordans 5
Moncler Jackets
Cheap Jordan Shoes
Jordan 12 Retro
Air Jordans
Moncler Outlet
Nike Website
Soccer Shoes
Nike Snkrs Website
Jordan 11
New Nike Shoes
Adidas NMD
Jordan Retro 11
James Harden Shoes
Air Jordan 10
Golden Goose Outlet
Cheap Jordans
Pandora Ring
Jordan 1
Jordan 6 Rings
Pandora Canada
Yeezy Shoes
Golden Goose Outlet
Jordans 13
Pandora Jewelry
Jordan 14
Jordan 3s
Nike Huarache
Moncler Jackets
GGDB Sneakers
Pandora Jewelry
Moncler Sale
Pandora Charms
Red Bottom Shoes
Pandora Canada
Jordan Sneakers
Jordan 9
New Jordans
Jordan Retro 5
Jordan 11
Jordan 11
Nike Mens Shoes
Air Jordan Sneakers
Jordan 11
Jordan 8
Louboutin Shoes
Moncler Store
Air Jordan 12
New Jordans 2018
Fitflop Shoes
Nike Air Force 1
