prefered voltages?
Posted: Thu May 31, 2012 9:56 am
What kind of voltages do you prefer in your 45/100s (at idle and when running)? Having tried voltages from 480 to 560v (at idle) in 4 different jtm45/100s w/kt66s, I think I prefer the sound of plate voltages around 520-530v. However, the higher voltages give a nice, punchy response though.
The marstran 1204-43 seem to sag quite a bit under load (like the originals did). When I tried the other day, one of my amps saged 40v when playing a little ac/dc (and even more when running flat out). Do the metro -43 sag this much?
Finally, what kind of choke are you running? I'm using the RS in one of my 45/100s and its 690ohm resistance brings down the screen voltage quite a bit (around 400v when running flat out, although its 525-530 at idle)
