Wanting to build a "influenced 45/100"
fusionbear
Post by fusionbear » Sun Sep 09, 2012 12:31 am
Hello guys. Some of you have built some amazing replicas, but I don't have the wherewithal or patience to build a replica. I want to build one that follows the circuit but am concerned about modern kt66's handling the high plate voltages. Any of you use a pair of KT88's instead of the quad of kt66's? What did it do to the tone? Will the kt88's still sag the power supply like the kt66's do?
Your thoughts and advice would be greatly appreciated... :drool:
Amps: diy SLO, Splawn QR, YBA-1
Cabs: Scumback, Rockit, Deizel
Speakers: Scumback M75, Cel. V30, wgs hm75
Guitars: Suhr, B.C. Rich
emmjaydubya
Re: Wanting to build a "influenced 45/100"
Post by emmjaydubya » Sun Sep 09, 2012 5:05 am
The M****n 1202-43 has a B+ option as low as 460 volts and the Marstran 1202-43 has a lower B+ option of 490 volts. Pretty sure the Gold Lions will handle this, you might want to do a search on them to find out.
BTW, I've been beating the crap out of a pair of cheaper Shugang KT66s in my JTM45 at 440 volts for about a year now without a problem.
HTH
Post by HTH » Sun Sep 09, 2012 7:26 am
(from memory), the real deal JTM45/100s run around 550v on the plates - I'd be wary of running current production KT66s at that voltage and expect them to be reliable. KT88s or 6550s all the way in this application.
OR, run those current production KT66s around 450v and they'll be happy as a pig in shit.
fusionbear
Post by fusionbear » Sat Nov 03, 2012 1:44 am
Here is some progress. Not period "Accurate" in the build, but definitely in the values. Hope to finish this weekend...
http://i169.photobucket.com/albums/u223 ... G_1440.jpg" onclick="window.open(this.href);return false;
axeman
Post by axeman » Sat Nov 03, 2012 7:01 am
Good job, keep on updating your build with pictures, also if you need any help I'm in Bellflower.
fusionbear
Post by fusionbear » Tue Nov 06, 2012 11:19 pm
Here she is:
http://s169.beta.photobucket.com/user/f ... 00%20Build" onclick="window.open(this.href);return false;
She sounds amazing. I will post some clips this weekend...
:jimi:
HTH
Post by HTH » Wed Nov 07, 2012 7:28 am
Nice tidy work, what kind of circuit did you end up with? - is it a hotrod? :hairband:
fusionbear
Post by fusionbear » Wed Nov 07, 2012 11:03 pm
HTH wrote:Nice tidy work, what kind of circuit did you end up with? - is it a hotrod? :hairband:
Just a bone stock 1959 circuit. The only deviation is a 100K PEC Bias pot, and a different layout for the caps and diodes.
Here are the values I used:
B1, 2-80uf's in series for 40uf total
B2, 2-30uf's in series for 15uf total
B3, 1-30uf
B4, 1- 22uf
HTH
Post by HTH » Thu Nov 08, 2012 2:44 pm
soundclips?
AJW
Post by AJW » Wed Nov 14, 2012 10:17 pm
That looks really good! :thumbsup:
fusionbear
Post by fusionbear » Sat Dec 15, 2012 7:30 pm
Some clips finally.
First clip: Straight in. High Treble: Maxed, Pres: 6, Bass: 3, Mid: 7, Treble: 7
http://www.youtube.com/watch?v=e0AXKYBd ... RA&index=2" onclick="window.open(this.href);return false;
Second clip: I used a load box into a DD7 into an early 60's Orange SL120 Mono tube power amp.
http://www.youtube.com/watch?v=o3UbTGLD ... RA&index=3" onclick="window.open(this.href);return false;
Xplorer
Post by Xplorer » Sun Dec 16, 2012 7:16 am
Very good !!!! bridge humbucker position ? i didn't try a humbucker with mine yet, 100 w version.
Really impressed by your Zappa clip, wow you can play ! what made you progress in this direction ? just hearing and try to reproduce it ? cause i'm not familiar with these patterns not so pentatonic i guess ^^ but a lot interesting.
fusionbear
Post by fusionbear » Mon Dec 17, 2012 10:54 pm
Thanks for your comments! I have always listened to all kinds of music. Just trying to improve a grain of sand at a time...
Yes, i used a humbuckers for the clips... :rock:
Xplorer
Post by Xplorer » Tue Dec 18, 2012 3:22 pm
yes i've heard several clips several times, really good, and tone !!
How do you improve a grain of sand ? :wink:
i mean, i'd look for some new ways to evolve in my playing. usualy i hear things, i try to play them a bit, but i don't learn things entirely. i've saved several particular hendrix, jeff beck, stones ......... songs, tabs, aside for my own school, for some interesting tricks and logics, technics, emotions .. things that i can't put out yet.
i never find the time to work on it. How did you work your sand grains ? i'm curious.
fusionbear
Post by fusionbear » Sun Dec 23, 2012 1:26 am
Just simple repetition. I hear something and I attempt to learn it and then add my own twist to it... :rocker:
