I will be super careful..
connect diodes to the low HT secondary but not stright to the choke. Connect it to a 550v cap first, then to the choke and another cap. Search CLC filter or Pi filter for a schematicniknik wrote:...
I suppose another full wave rectifier rail from low HT secondary, than straight to choke and to a filter cap (or maybe the contrary, I don't know), and than straight to screens with no res in pins 4.
Also modifying main rail supply, going from mains to PI through a 100ohm resistor..
is it quite correct?
when the amp will be ok, I'll do some clips
32uf or lowerniknik wrote:Thanx Roe,
I think I figured out how to do this mod..
What the recommended value for the filter cap before the choke is? 32uf, 50uf, 100uf, any one of these?
niceniknik wrote: Next I will do some sound test with fuzz engaged and I will post my impressions..
great! does 100uf sound stiff on the screens? Originals have 16uf. Also, why not connect the phase inverter and the preamp to the screen supply with a 8k2 or 5k6 resistor instead of the plate supplyniknik wrote:Thanx Roe,
I have performed the separate supply mod for the screens in my 45/100, by using low ht taps from PT, with no disasters!![]()
What I did is: in main rail supply I have changed the choke with a 100ohm resistor and disconnected the wire going to screens.
From low HT tap I did another full-wave rectification, same as in main rail, than I went to a 22uf filter to ground, than to RS 20h choke, after this went to a 100uf filter, and finally to the screens.
I also changed standby spst switch with a dpdt one, one side for main, and the other side for screens supply.
I reset the bias at 28ma per tube, and now the amp b+ is 548v, sagging to 490v at full power, and the screen current stays at 485v at idle, sagging to 357v at full power.
Amp tone is not so different from before, a little cleaner and focused maybe, but not huge difference here.
Main difference is that kt66 tubes show no more blue flashes, when picking the guitar strings.
sensation is that the amp is a little more "relaxed" also in full power conditions, if it makes a sense..
I hope my explanation is undertandable, it's a bit difficult express myself correctly in english language..
thanx Dave!daveweyer wrote:Usually you would want to use the higher value cap in the first position and lower value cap after the choke. If you run the preamp stages from the low voltage supply for the screens, you will have less hum in the circuit because you will have an 18 db rolloff from the two caps and choke. Normally the plate supply does the sagging, and the screens are kept steady with larger caps, but you can experiment with it to get the sound you like. The KT66 tubes will be much better protected with the separate supply for the screens. I tried to talk Jimi Marshall into doing this back in '69, but apparently there was too much growing and shuffling at the company to take time for this small redesign.
I think 1k screen resistors are ok, because with separate screens supply from low HT, voltage is only 484v in screens at idle, way lower then with 2k2 and main supply connection (it was 541v).Xplorer wrote:isn't lowering the screen résistors back to 1k bad for the tubes ?
what is the bias value ?
