Hendrix set up.
- stalkertwo
Hendrix set up.
i, i want to ask about the Hendrix set up effects, I'm interested in Hendrix fuzz and amp, fuzz i have settings on volume half, and fuzz almost max. Amp is gain 5, treble 5, bass 3. While is Hendrix fuzz such light and slight. I don't get to how i set up all my effects. Thank you, MUSIC IS MY RELIGION
- stalkertwo
Re: Hendrix set up.
Please.
Re: Hendrix set up.
What Amp and Guitar are you using ?
Re: Hendrix set up.
You need the amp set up clean with just a little break up, turn the fuzz and volume all the way up use the volume on your guitar to control the fuzz
- stalkertwo
Re: Hendrix set up.
Guitar vintage jmh strat model, amp fender super champ x2. And i using treble 6, gain 5, bass 2-3.
Fuzz how i set up, fuzz is almost to max, volume half.
- stalkertwo
Re: Hendrix set up.
You can show fuzz settings on picture please.
- stalkertwo
Re: Hendrix set up.
I have pictures https://plus.google.com/u/0/110976034384530349234/posts
just click pictures and is it.
Re: Hendrix set up.
You might be interested to know that Jimi didn't use the fuzz on his fuzz face units, just the extra gain, and he used that to overdrive the input stage of the amps he was using, mostly Marshalls, later in his career.
When his equipment would show up at West Coast Organ and Amp, the fuzz would always be turned down. I modified all the fuzz face units for more depth, among other things that Jimi wanted to try. Just thought I'd set the record straight, since I happened to see the post tonight.
Re: Hendrix set up.
I couldn't play your links ... Turn the Fuzz Volume and Fuzz all the way up then use the guitar volume to control the fuzz
- stalkertwo
Re: Hendrix set up.
You click photos and album. So i have set up fuzz almost on max, and volume on half. I will be using knobs on guitar
Re: Hendrix set up.
Yes but Volume on Fuzz near Max also
Re: Hendrix set up.
Also What Fuzz do you have ?
- stalkertwo
Re: Hendrix set up.
Volume too on max?, fuzz i have near max. Anyway i have dunlop Jimi Hendrix fuzz face. fuzz blue.
Re: Hendrix set up.
Did you happen to see his amps. What were the controls set ondaveweyer wrote:You might be interested to know that Jimi didn't use the fuzz on his fuzz face units, just the extra gain, and he used that to overdrive the input stage of the amps he was using, mostly Marshalls, later in his career.
Re: Hendrix set up.
When the amps would come in they would normally have the controls up around half way, depending on the gig. As you have probably seen, Jimi would sometimes just run his hand over the controls, turning them all the way up, every last knob. He did this when he didn't feel the power he wanted, either just an emotional response, or a response to an audience vibe or bad room/sound.
The tone and volume controls on Marshall 1959 amps don't make all that much difference once the amp is well into distortion, the sound is contoured mostly by the output stage and the speakers. In the 1959 amps, like the 1959 Bassman, the tone control circuit is the last thing before the power stage, it works on everything but the distortion in the power tubes and phase inverter/driver.
On numerous occasions, Jimi just wanted more, more of everything, especially power. More output power allowed more tone flexibility on stage. With enough power, his halfway settings allowed him to go both ways with the knobs and still get some effect from them.
Overdriving the input stages of the amps with extra gain from the Fuzzface gave him that ultra-feedback regeneration he needed for the "sonic avalanche" stuff. He didn't like the real buzzy stuff from the fuzz, or at least that's what he indicated to me, and he didn't use the Fuzzface too much, especially in the more bluesy kind of playing, the sharp clean edged overdrive that everybody loves.
DW
DW
