Billy Batz - Better late than never? By all accounts, sounds like this could be the cure. Makes sense, anyway.
raiken wrote: No, that is normal - you will get a larger output swing from one phase to the other when you hit clipping - that is a characteristic of a long-tail pair phase inverter. The "input" side, which is functioning as a common-cathode stage, will have a larger clipped output than the "other" side, which is effectively functioning as a common-grid stage - remember, it is amplifying and inverting the "clipped" wave from the other section.
Having said that, the relative matching of the two sections, while unimportant when the PI is not clipped (due to the local and global feedback that tends to stabilize the gains), will affect the drive when clipping, so you may see a difference with different tubes.
Randall Aiken
Always read that the Long tail pair was unbalanced. Just really surprised that I had such a huge difference when dimed! 30% less! Didn't expect THAT much. It was nearly identical at lower volumes. Go figure. Thanks for the explanation. Scope has turned out to be a really useful learning tool.
18w implementation schematic here, if you missed it. http://www.paulamps.com/18watterbuzz.html#ResistiveLoad
