Restoration For '68 JMP Super PA 100 watt
deliturko
Post by deliturko » Tue Oct 28, 2008 8:09 pm
Hi guys,
Need help for restoring this beauty :D Power trans. is not the original one, cap board looks not good and phase invertor can cap is not wired, you will see 3 extra caps on bias circuit and also it has a additional cap wired on the main board near the 32 uf dual cap.This amp looks good but with your help it will be pretty nice again :twisted:
My idea is, split cathode for one side an add some other things on the 67-68 circuits and I'll leave the other side untouched.
Since its a super Pa which I dont have any opinions about 2 days before :D but it looks similar to 100 watt superleads.I have checked the layouts pre, power amp and cap board wiring is same with brige rectifier.I've decided to use Metro Amp Drake 1203-80 transformer for replacement.Is that ok ?
There is nothing on output trans, what is it Drake 2" or Dagnall ?
Anyway these are the pictures
Minimass looks really tiny in here :lol:
Mustards look so nice :P
No bias pot on it and yellow dudes are 47 uf 350V caps
It's serial number is SP/20527
deliturko :wink:
908ssp
Re: Restoration For '68 JMP Super PA 100 watt
Post by 908ssp » Tue Oct 28, 2008 10:41 pm
Well I have a 45 watt Super PA and it is a terrific sounding amp. I would not mod it if I were you. I'd repair it for sure make it has stock as possible. The Metro PT is a good one so is the Marstran both of those have a more vintage vibe than the MM transformer. I play mine with an a/b box feeding one channel at ten and the other channel at 6. I use a treble booster, fuzz or distortion pedals in from to get any extra gain I might need and the PA works assume for that. Any mods on old amps like that detract from the value and the Mojo in my opinion. Get a Metro kit if you want to try your hand at modding.
deliturko
Post by deliturko » Wed Oct 29, 2008 6:08 am
Well, you are right about moding a vintage amp.But it has 2 identical channels per side :) Anyway at first I have to repair it :wink:
What are your suggestions for filter board caps ? 100 uf and 32 uf seems to be standart on layouts for its era.
I'm going to change cables, sockets,power trans, switches,pilot lamp, pots/knobs list goes on...
Post by VelvetGeorge » Wed Oct 29, 2008 11:30 am
Well, you do have some work to do. But I wouldn't change anything that doesn't need to be replaced, at first.
These might help:
http://metroamp.com/wiki/index.php/Cate ... is_Layouts" onclick="window.open(this.href);return false;
http://www.amparchives.com/album/Marsha ... index.html" onclick="window.open(this.href);return false;
deliturko
Post by deliturko » Wed Oct 29, 2008 11:45 am
Thanks George you are the best :D
Post by neikeel » Wed Oct 29, 2008 1:45 pm
deliturko wrote:Well, you are right about moding a vintage amp.But it has 2 identical channels per side :) Anyway at first I have to repair it :wink:
Are the switches, lamp, pots and knobs wrecked? They all look to be original parts. If not broken I would purely replace what is broken or cannot be repaired.
A bulgin looks neater than the kettle socket too.
It would look like yours was 100+100 in series on mains and 32+32 in series on screens. It looks very similar to my Superlead which has a Hunts 16+32 for the PI.
Pics of mine are here (its clone is there too :wink: ) part way through restoration:
http://forum.metroamp.com/viewtopic.php ... ad#p182871
It dates to second quarter of 1968 (mustards and pot dates). It even has the 47pF Murata ceramic cap in the PI like yours.
Pre restoration pics are here:
http://forum.metroamp.com/viewtopic.php ... ad#p133868
deliturko
Post by deliturko » Wed Oct 29, 2008 4:54 pm
Hey thanks for the photos :wink:
Can cap is 16+32 Hunts too, and switches look bad but still working, pilot light is a Fender type lamp hanging over there original light's red glass still there also.Pots needs cleaning or replacement I dont know.Amp's main problem is the power trans, sockets,and electrolytics.2 knobs missing and rest are not good looking and of course lots of rust on some areas.
More pictures
Now making parts list.
Post by neikeel » Thu Oct 30, 2008 6:24 am
Your OT is Dagnall C1998
The PT should be a Dagnall T2562. George had a short run of these made up (I had x2, one for the blown one in my origianal and one for the clone). Not sure if he has any left. His Drake 1203-80 will certainly do the job admirably, just does not have the copper shielding that the Dagnall does.
deliturko
Post by deliturko » Fri Oct 31, 2008 5:25 pm
Hey guys,
Today I found these in a local shop :twisted: Mustards are 0.15 uf 400V ( mostly NOS but used ones available) Can I use them instead of 0.1s in Marshall circuit? Btw most of the resistors are 2 watt CC :twisted: and everything cost me just 20$ with 10 percent discount :P And I'm going to buy 30 more mustards tomorrow :twisted:
Now I just need new Power trans and some nice electrolytics then I will start to work on the amp.
DT
Post by neikeel » Sat Nov 01, 2008 5:02 am
You can use those 400v mustards but if the others ain't broke..........................
The 0.1 looks like 160v - only place you can use that is on the presence pot.
I would clean and test what you have first.
I suppose you might have an issue with that warning lamp :roll:
deliturko
Post by deliturko » Sat Nov 01, 2008 5:12 pm
You are right, 0.1 is 160V.
Today I removed the cap board and preamp board for cleaning.Preamp is ok.I won't change anything.Unfortunately power tube sockets are dead.Pots are still fine no replacement needed.
DT
deliturko
Post by deliturko » Sun Nov 02, 2008 5:32 pm
Hi,
I have a question, how about Hammond power transformer model 290HX for replacement ?
deliturko
Post by deliturko » Sat Jan 10, 2009 7:58 pm
Hi,
Finally amp is ready for testing here are the pics.
Mods; split cathode for channel 1 and 2, shared for 3 and 4. 500pf cap added on mixer resistors, filtering on screens now 32uf.New 6V pilot light and switches.Cathode bypass cap on V3.I also changed all tube sockets.
deliturko
Post by deliturko » Sun Jan 11, 2009 5:00 pm
Hi,
Today I've tried the amp,there are some problems;
One of the 1 ohm 1 watt metal oxide resistor(V6) was burned, I checked the bias voltage it was about 80ma :!:
I set the bias about 35ma, my plate voltage was 470V and screens were 450V and put an alligator clip on pin 1 of V6 for the grounding.After that it worked, all channels and controls were operational.After five minutes I wanted to crank it up when I set the volume over 4 I heard loud crackling noise (on both channels) That was realy annoying.
Any idea about the problem ?
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 2:26 pm
Air Jordan Sneakers
Cheap Nike Shoes
Pandora Jewelry
Nike Shoes
Golden Goose Outlets
Jordan 6
Golden Goose Sneakers
Jordans 13
Moncler
Yeezys
Nike Air Force One
Jordan Retro 12
Jordan Shoes
Air Jordan 4s
Nike Outlet
Jordan 11 Retro
Air Jordan Retro 10
Pandora Rings
James Harden Shoes
Jordan 11s
Pandora Bracelet
Jordan 11 Low
Moncler Outlet
Jordan 3 Retro
NMD R1
Jordan Retro 14
Pandora Ring
Nike Mens Shoes
Jordan 5
Pandora Jewelry
Nike Air Max 95
Jordan Shoes
Moncler Jackets Outlet
Moncler Outlet
Pandora Charms
Cheap Jordan Shoes For Men
Fitflop Shoes
Yeezys
Golden Goose Sale
Red Bottom Shoes
Jordan Retro
Pandora Jewelry Official Site
Jordans 11
Nike Snkrs
Pandora Jewelry
Pandora Official Site
Golden Goose Shoes
Nike Air Max 270
New Jordans
Jordan 4 Retro
Jordans Sneakers
Kyrie Irving Shoes
Nike Sale
Yeezy Shoes
Nike Air Max
Jordan Retros
GGDB
Jordans Sneakers
New Jordans
Fitflops
Outlet Golden Goose
Pandoras Jewelry
Jordan 9
GGDB Sneakers
Jordan Sneakers
Jordan 11 Win Like 96
Moncler Outlet Store
Jordan Retro
Jordan 5
Moncler Vest
Golden Goose
Nike Air Max 98
Nike Air Max 90
Adidas Yeezy
Jordan 11s
Jordan 11
Nike Website
ECCO Shoes
Jordan 1 Retro
Jordan Sneakers
Red Bottoms Louboutin
Nike Air Force 1
Jordan 3s
Jordan 11 Red
Pandora Charms Sale Clearance
GGDB
Soccer Cleats
Louboutin shoes
Ferragamo
Nike Women
Golden Goose Mid Star
Yeezy
Air Jordan
Jordan 6 Rings
Nike Shoes
Air Jordan
Hermes Birkin
Jordan 11
Air Jordan 5 Retro
Red Bottom Shoes
Balenciaga Triple S
Jordan Shoes For Women
Jordan 12 Retro
Jordan Retro 6
Air Jordan 12
Jordan 4 Retro
Nike Outlet Store
Adidas Yeezy
Valentino
Ferragamo Outlet
Balenciaga Sneakers
Cheap Jordans For Sale
Pandora Canada
Fjallraven Kanken
Pandora Charms
Nike Outlet
Retro Jordans
Golden Gooses Sneakers
Air Max 2018
Moncler
Moncler Jackets For Women
Harden vol 1
Nike Outlet Store Online Shopping
Jordan 4
Jordan 8
Nike Outlet Store
NMD
Jordan Retro
Nike Outlet
Jordan 11
Air Jordan 11
Jordan 12
Nike Huaraches
Moncler Coats
Louboutin Shoes
