No Big Deal Mike,
Hey what can anyone tell me about the Military spec Pots and Sozo Caps. I trying to learn all I can before I order. As far as the Big thing goes Ive been trying to blame it on my wifes Italian cooking but no one
believes me!
Jim
PRS Mccarty
Fender AM Deluxe strat
Hand Built (by me) Les paul jr
Fender Tele
Marshall DSL 100
Big
- Big Mike
Re: Big
The sozo's are said to sound better, enough people I trust agree, so I went for that with my kit.
With the pots, I went PEC because they're made in Canada. After 6 or 7 years working with an electronic component manufacturer that brought stuff in from China, I wanted as much 'domestic' build as I can. LOL
I like the feel of the PEC pots, and felt it worth the upgrade. I'd get another set of fastening nuts if I were to do it agian, to position them back in the chassis a bit more. And I did manage to get solder to stick to the backs, but it sounds like I got lucky. LOL
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
Scumback Speakers
- Big Mike
Re: Big
Ooops I think you started anew thread. LOL
Scumback Speakers
Scumback Speakers
- novosibir
Re: Big
Guys, that's not the right forum for this kind of discussion
Therefore moved here. Please keep an eye on the forum's title and also the line below!
Larry
Larry
Re: Big
Can't comment on the pots but I can with the Sozo caps. I built George's 69 kit lead spec, when I first got it there was a mix up in my order, and I got Mallory caps instead of the Sozo's. With my original order I had added some additional Sozo's to try bass spec as well and I got those. Metro of course made things right and sent me the Sozo's that I should have got in the original order, so no issue there.Big Jim wrote:No Big Deal Mike,
What I am getting at is I didn't wait on building the amp untill the other Sozo's arrived, so I ended up using the extra Sozo caps for the PI part of the circuit and the preamp and mixer area had the Mallory's when I first fired it up.
To me, I won't say one is better than other, they are different. The Mallory caps are more modern feeling when you play the amp. Like faster attack, a bit harsher, but not in a bad way. What was cool was taking that amp built that way, diming all the controls except bass off into a Hotplate set to load, graffic EQ, to a solid state power amp. Very very bright tight sound. Then EQ boosting bass way up around 100hz range. Great metal sound, but not what I am into anymore. Would have loved it 15 yrs ago.
With all Sozo's (standard ones is what I have), a bit more give and a little less harshness, this is working better for me, along as other mods to make the amp less harsh. Am more into the classic rock and VH thing, I like the Sozo's better. Have yet to try the vintage Sozo's.
Re: Big
i have two super leads that have all mustard caps....
also have other SL's with all sozo "standards".......
i cannot tell a difference.....did a "blind" a/b test w/ a friend....he could not
pick out the all "mustard" amps.....or sozo amps, for that matter!!
money well spent
money well spent
