Speaker Out on a Lead 12 5005
OdgeUK
Post by OdgeUK » Sun Mar 25, 2012 12:20 pm
What exactly do I need to do to get a Speaker Out on my 5005 (Marshall Lead 12)? I want to hook it up directly to my 2x12 Cab rather than Line-Out to another amp's Power Section.
I'm thinking that I could utilise the HP / Line Out jack? If so, is it just a case of flying the two Speaker wires over to the Headphone Jack?
73 JMP 1987 w/LarMar
78 JMP 1987
79 2104
Peavey JSX 120
Marshall 1936 G12-65
Gibson LP Custom, Squier CV 50's Strat w/SD '59
pjoliver182
Re: Speaker Out on a Lead 12 5005
Post by pjoliver182 » Sun Nov 20, 2016 5:06 am
Did you do this in the end? I was going to add an extra jack on the back and connect it by snipping and extending the existing speaker wires. With nothing connected to the jack, the signal would go straight across to the 10" speaker. With a plug in the jack the connection to the 10" would be broken and the signal tapped to an external cab.
