The PPIMV (Post-PI-Master-Volume) thread.
Re: The PPIMV (Post-PI-Master-Volume) thread.
It was a passing attempt at making the bugger work.
So pin 5 but I guess I doing my best with the layout and I have done it correctly before on a Marshall.
My bigger question is if the PPIMV is wired the same on the Tweed Bandmaster as it would be on a 50 watt Plexi?
Or should I use a different approach to MV on the Tweed Bandmaster?
If it's too loud, your too old.
they should be the same. you said you wired the ppimv to pin 4 of power sockets, your bias voltage goes to the grid ressitors on pin 5, pin 4 is your screen grids. you should find a schematic of your amp and compare the two.
Hank S wrote:It was a passing attempt at making the bugger work.
"purple power rules"
I am back to pin 5 but I think there must be something I did while removing the extra jack
I don't know then. retrace your work or post some pics.
- CoffeeTones
That layout is awful quality. This is less cluttered http://www.ceriatone.com/images/mods/Type-2-MV.jpgHank S wrote:I have a Tweed Bandmaster 5E7 amp that I am attempting to adda ppimv but I have no sound. Using the layout I assume (cough) that it should be the same as this: http://forum.metroamp.com/download/file.php?id=17637 But I get no sound. I stole the second speaker output for my pot location and I'm just not sure what is wrong. I removed the 220K and I'm going to pin 5 on V4 and V5. I even moved these to pin 4 because I thought that maybe they should be before the resister.
Is there something different about this amp that makes it not a good MV choice? I have put one in a Marshall before and went quite easily.
just checked out that layout, yeah that's a bit messed up n cluttered
I have the Rich Mod II in my 1969 Super Lead and I absolutely love it. Great response and decent transparency, I see why George prefers this version.neikeel wrote:I guess you will have to ask him! The 'Rich Mod' does add a litle extra distortion of its own. I had it in a JMP50 and quite liked it, ideally I should try back to back.AndyK wrote:Is there a reason why George likes the Rich mv over the LarMar?
However, I'm sort of curious what you mean by "the rich mod does add a little extra distortion"? I was under the impression that this mod was rather non-intrusive and was basically out of the circuit when at full volume. How could it "add gain"?
Okay, stop me if you've heard this one. You go crazy trying to figure out what you've done wrong doing a mod and then put the amp back to where you started and it just fereeeking doesn't work. Then you check the tubes under the tube covers and see one has a hazy foggy look to the glass.
So I change the tube and the amp works. So now let me try this again….
- CoffeeTones
Remove the covers and store them. The amp will sound better and you can see the tubes. Was it the phase inverter tube?
It was V2 a Mullard reissue
So, I installed the ppimv and it works!
I'll have to wait to really feel it out later today. Mostly I want a bit fuller sound at lower volume. I'm going to reinstall my 1973 Traynor alnico speaker that is warm and inefficient.
- CoffeeTones
Elevate the heaters and V2 tubes should last longer - even the cheap ones.
Why is that? I also have covers on my tubes, so curious why they sound better without.CoffeeTones wrote:Remove the covers and store them. The amp will sound better
- CoffeeTones
They change the internal capacitance of the tube.
I'm confused on this comment. How does the Rich Mod add "extra distortion"? I have this PPIMV on my Super Lead and I love it. But to me it's just the same tone I get with the amp cranked. I don't notice any "extra" gain.
Could you elaborate on this comment?
Allright, so a little bit less bit when tube covers are on?
