I´ve built an 1959 with ppimv from a chassis and transformers of a dead jcm2000.
Everything works, but there´s some things that i wonder is normal behavour for this circuit.
Is it normal when the bright vol is above 6-7, to start to get muddy? even with 0.002coupling and 0.0047bright?
Specs:
bright channel
680n/820ohm
0.002 coupling
bright cap- 3 to chose on a switch 4.7n, 500pf and 100pf
1959 "normal" behavour
- jerrydyer
Re: 1959 "normal" behavour
using the ppimv or not using it or both?
should be rockin. the ppimv sounds weird with only 2 gain stages though.
vids.
