Importance of pot quality in Lar-Mar master volume?
Posted: Sun Oct 07, 2018 12:41 pm
I've tried to search but the Lar-Mar thread is so long I can't really find a definitive answer.
I have only built one amp with a Lar-Mar master volume and used a dual Alpha pot I had. I found out that I actually liked the master volume a lot in that amp, so I'm thinking about adding it to one or two of my other builds for practical purposes. But I am wondering if it makes a significant difference to use PEC pots insted? I know George is a big fan of the PEC dual pots for his master volumes, but IIRC he is using a different type of PPI master volume, is that right? With the Lar-Mar, does it make any sense to buy the much more expensive PEC type? The rest of the pots in these particular amps are Alpha FWIW.
I will try a zero-loss FX loop in these same amps, but that shouldn't have a bearing on my choice, I would assume?
