Post
by JoeM » Sat May 29, 2010 2:40 pm
Hey everyone,
I finished up my build today and was able to fire it up. EVerything went pretty smoothly. As i was biasing, the V7 tube was set at 35 mv , V6 was 30, V5 was 29, V4 was 30. Seemed like i was at the limit of my " matched set" of my JJ's . I plugged in a guitar and was playing for playing for roughly 10 minutes with no problems or strange noises. I put the amp on standby, got a drink, i took the amp off standby and heard some strange noises coming from my speakers (think moogerfooger) and then i blew the 4 amp fuse. After replacing the fuse, i turned the amp on and tried to check bias....my V7 tube which was high before was now down in the 25mv ranger and the other tubes were racing up, i shut the amp down as they approached 40 mv. I didnt notice any redplating since everything happened kinda fast. After removing the tubes and rechecking all my voltages, i replaced the tubes with a different set ( winged c ) and turned the amp back on. I biased the tubes and then rechecked them again. V4-7 all had a pin 3 voltage of 479, The mv reading was V7-32, V6-33.5, V5-34, V4-31.8
Im assuming for right now i blew the JJ tube at V7. Ill have a friend check them for me on his tester tomorrow. For now im gonna keep playing and keep checking the bias and watch for any redplating.
- IMG_0233.JPG (115.76 KiB) Viewed 1311 times
