Hi!
Here's my latest build.
Marstran T2562 PT
Marstran C1998 OT
Marstran C1999 3H choke
Brian's boards
Valvestorm's components
Metro chassis and plates
The only thing I'm a little concerned about is the B+ I get, measured at pins 3 of the power tubes. I have 528VDC there with power tubes installed... The amp sounds great anyway, I played it for three hours at a stretch but maybe I should find a way to reduce that? The tubes are biased at 33mA. I have a 228V wall voltage and the amp is wired for 230V operation... What do you think?
http://imageshack.us/photo/my-images/812/widei.jpg/
New 12XXX brought to life
- vanhalen5150
Re: New 12XXX brought to life
Post a chart of all your pin values. That would be considered a bit high with North American wall voltage, but maybe thats normal with the higher 230.
Might want to post over on the Marstran forum for ideas. I assume your PT is not one with the lower output voltage taps. His 1203-80 has the lower taps. You could try wiring it for 240v... that would lower the output some, but not a lot.
- Gunny Highway
- Gunny Highway
Hi.
Thanks for your input guys! Brian at Marstran answered me and said " your B+ is high but not too high". So I'll leave it as is... The amp sounds great anyway, so why bother... As musicians we should rely more on our ears, and leave the DMM for earlier steps...
Cheers!
Cheers!
- vanhalen5150
As your tubes, caps, resistors break in a bit, I'd bet your voltage will come down a little.
- rgorke
Are you using a variac?
Nope...
