Question about pre-amp cap wiring and cap board caps.
Posted: Thu Jan 05, 2017 6:50 am
Comparing .pdf's of the '67/'68 and '68, I see that the boards pre-amp cap -negative uses either/or free terminal to ground as it does not make a difference there.
Does the wiring have any affect that it is using the other + terminals, that the 10k resistor is on ? Signal is coming in from the other side of the 10k to the other ) terminal...
Should it also be the same, and have same affect wired like the other, correct ?
On the cap board: Axials on the '67/'68 and dual's on the '68 ?
