Mallory 150 series?
revolver1
Mallory 150 series?
Post by revolver1 » Tue Aug 22, 2017 5:02 am
I have some .22uf, 630v Mallory 150 series caps. Would these be any good as snubber caps?
I also have some Xicon polypropylene .22uf, would these be any better?
Re: Mallory 150 series?
Post by VelvetGeorge » Tue Aug 22, 2017 1:40 pm
Snubbers across the HT diodes? Yes, they are suitable. Though I'd prefer caps with higher voltage ratings there.
Post by neikeel » Tue Aug 22, 2017 4:11 pm
Aren't they usually 1000v rated?
RockinRocket
Post by RockinRocket » Tue Aug 22, 2017 7:12 pm
Ive seen Dubliers makerd with 600v on some stock Metal panel amps
revolver1
Post by revolver1 » Wed Aug 23, 2017 1:40 pm
Thanks guys, better play it safe and get some higher voltage ones.
:toast:
revolver1
Post by revolver1 » Wed Aug 23, 2017 4:35 pm
Right then fellas I need some schooling. I've been looking at caps and have got myself completely confused.....
So I've been looking up 1000v caps and I'm turning up 1000vdc which turns out to be 500 to 600/630vac. I can appreciate the difference between a.c. and dc but for the hv diode snubbers is it 1000v a.c. or dc I'm after?
Am I right to think a.c., pre rectification?
Also best cap type for this application. Metalised polyester or metalised polypropylene? And the reason behind it?
I have used the Xicon metalized polypropylene before but am thinking astheticaly that a tubuar cap would look the part. Obviously performance for the task is most important but i dont know enough to make an educated decision.
Any recommended type and or brand?
Cheers
Post by neikeel » Wed Aug 23, 2017 6:03 pm
as I understand it modern spec diodes do not create much hash so you dont really need them
but yes 1000vdc is what I would expect.
Post by VelvetGeorge » Wed Aug 23, 2017 6:25 pm
If the cap is in parallel with the diode you really have pulsating DC, with high frequency switching noise. If it's from the output of the bridge to ground, then it's DC, still with switching noise.
Correctly rated would be 1000V DC, over twice the expected DC voltage.
If you use faster diodes a lot of the noise is eliminated and the snubbers are not necessary. Try UF4007's.
revolver1
Post by revolver1 » Thu Aug 24, 2017 1:59 am
Thanks guys, I've already staked out the circuit boards I made from scratch. I don't really want to try cut off the ends
One of the bords I made from paxolin and it chiped so easily it took quite a few attempts to make one without any chips or blowouts.
I've got the big fat fast recovery diodes so It sounds like I don't really need the snubbers. I'm going to get some anyway to be vintage correct and because I don't want to cut the end of the bords off.
Post by neikeel » Thu Aug 24, 2017 6:01 am
http://www.ebay.co.uk/itm/1-Pkt-RS-Comp ... Swe4ZZlsY9
These RS branded Dubiliers will look the part!
revolver1
Post by revolver1 » Thu Aug 24, 2017 1:35 pm
Neikeel you are truly a gentlemen. :toast:
I bought some Cornell Dubilier 940c 1000vdc metalised polypropylene this morning. Those RS are really the business so they are going in instead, perfect! Thank you.
So when George said about the snubbers being in parallel with the diode is this like what I have seen on the newer re-issues? I was planning on doing it like in most of the layouts I've seen here with the two caps on the end of the board.
revolver1
Post by revolver1 » Thu Aug 24, 2017 1:47 pm
Didn't think of this but is there a reason not to use snubbers?
Post by neikeel » Fri Aug 25, 2017 2:51 am
Only if they fail!
You see many people remove them on 50w amps when the PT fails (for the bias winding problem usually) so they rip out the snubbers and the diode block, typically use two 1N4007s and leave out the snubbers in a shotgun approach.
I doubt they fail but are whipped out randomly - someone else may be able to disabuse me of this theory.
revolver1
Post by revolver1 » Fri Aug 25, 2017 9:41 am
Looking at building a 50w, dare I ask what's the bias winding problem?
Post by neikeel » Fri Aug 25, 2017 10:10 am
In 1969 with advent of the stand up PT and brown fibre board, block rectifier and snubbers Marshall committed a howler where the white bias feed wire came off the HT after the standby switch so the output tubes saw HT a the same time as the bias voltage, the theory goes that big inrush currents ensued, output tubes suffered and PTs died. Earlier laydown PTs take bias feed before the standby switch so the tubes get bias before HT. Later amps (72 on IIRC) had this changed. later amps also get simultaneously switched live and neutral via a DP mains switch - much better as well.
You need to ensure the bias wire comes directly off the ac feed from the PT (before the HT).
If you use a GZ34 rectifier you could avoid a standby switch. Other amps with less marginal PTs (like 70s Oranges) cope without a standby but they have dedicated bias windings (not just a spur off one leg of the HT ac).
