JTM 45/100 Speaker Ohms
I just thought I would confirm 100% (because I know that there are differences with some implementations from different builders) when using the Metropoulous JTM 45/100 replica if I was to attach two 16 ohm speaker cabinets then I should set the dial on the back of the amp to 8 ohm? Extremely stupid question I know it is just that I have seen different wiring of various JTM 45/100 builds and with two transformers vs one it is always best to check...
Re: JTM 45/100 Speaker Ohms
Yes.
