Hi. I have a Metro JMP 50 w plexi which I bought seceond hand this summer. It's been working great till it suddenly started to blow the mains fuse, right when I turn it on. Any suggestions: I have tried to change the El84 and the rest of the tubes, but same thing happens?
Best from
Norway.
Blows fuse
Re: Blows fuse
Did you check the bias, PT?
Re: Blows fuse
Hi and thanks, but I don't know how to do that?
- VelvetGeorge
- Site Owner
Re: Blows fuse
Your Metro 50 should have EL34 tubes, not EL84. Please double check that.
To troubleshoot:
Pull the output tubes and replace the fuse. Does it still blow?
Remove the HT fuse. Still blow the mains?
Most common reasons a working amp will start to blow the mains fuse are:
an output tube shorts
a diode in the power supply shorts
To troubleshoot:
Re: Blows fuse
El34's offcourse, but I'll check testing you suggest.
The two speakeroutputs by the way, are they f x 16ohm when using both or do the change the ohming?
Re: Blows fuse
Whatever I do according to your suggestions the fuse blows.
