JTM 45 Metroamp DIY - resistor question
Replica amps built by George Metropoulos himself. Visit PlexiReplicas.com.
Silmaril
Post by Silmaril » Tue Dec 18, 2018 6:30 pm
In the Assembly instructions there is one 100K 2watt metal oxide resistor recommended. Is it ok to use a 100K 1 watt Carbon Film resistor? what is the consequence?
danman
Re: JTM 45 Metroamp DIY - resistor question
Post by danman » Tue Dec 18, 2018 7:26 pm
The originals would have had 1 watt resistors in the B+ line and 1/2 watters everywhere else. Sometimes kits supply larger resistors so the leads are long enough to span the turrets. You should be fine using it anywhere in the amp except for the screen grids on the power tubes. These should be 5 watt or larger.
alexradium
Post by alexradium » Wed Dec 19, 2018 2:24 pm
carbon film are not indicated for power supply,they burn very easy when capacitors and tubes go bad,use metal oxide,ceramic wirewound or Vishay Dale 3/5w wire.
