garbeaj
Post
by garbeaj » Mon Mar 30, 2015 8:33 pm
rgorke
Post
by rgorke » Mon Mar 30, 2015 8:55 pm
garbeaj wrote:
Look how that high E string is barely on the fretboard, if at all!!!
Thanks Alan!!
JimiJames
Post
by JimiJames » Mon Mar 30, 2015 9:03 pm
yes, Thanks !
Build's ♫ Clip's ♪ Vid's
garbeaj
Post
by garbeaj » Mon Mar 30, 2015 9:24 pm
Yes...and conversely, look at how much extra space there is on the low E string on the opposite side of the fretboard!
GilmourD
Post
by GilmourD » Tue Mar 31, 2015 9:05 am
garbeaj wrote:Yes...and conversely, look at how much extra space there is on the low E string on the opposite side of the fretboard!
Could just be a funny angle... But the body looks straight on. Weird. Did somebody bump the neck loose?
rdodson
Post
by rdodson » Tue Mar 31, 2015 9:34 am
GilmourD wrote:garbeaj wrote:Yes...and conversely, look at how much extra space there is on the low E string on the opposite side of the fretboard!
I've explained this before but here goes: the body was cut to the then experimental bigger neck pocket dimensions that Charvel was then toying with (and later became standard). The neck was cut to Fender standard (and what would later be used for the Warmoth templates when LE sold to Paul).
Ed slapped it together and didn't know how to align when he drilled the neck mount pilot holes. He references this in a Guitarist interview when he spoke of the difficulty in mounting the neck. The neck was crooked, the bridge was put on improperly...it was a total POS. Good tone, but a horrible guitar.
Ron Dodson
Dallas
Romans 9:16
garbeaj
Post
by garbeaj » Tue Mar 31, 2015 12:28 pm
If it isn't obvious to everyone at this point...Ron is absolutely, 100% right.
rdodson
Post
by rdodson » Tue Mar 31, 2015 1:20 pm
garbeaj wrote:If it isn't obvious to everyone at this point...Ron is absolutely, 100% right.
I think it is quite ironic that most everyone here would give all their equipment for that guitar in original form...then we'd all either not play or want to modify it. What makes it cool is what it was used to do and who used it.
It is like the holy grail in that capacity. The Carpenter's cup was most likely nothing special.
Ron Dodson
Dallas
Romans 9:16
- Wiki Editor
Post
by NY Chief » Tue Mar 31, 2015 1:32 pm
The guy was a hack as much as we all were at that age.
Rich_D
Post
by Rich_D » Tue Mar 31, 2015 4:55 pm
Correct, it has been established and marveled at that the high E hung off the damn fret board for all that brilliance.
vanhalen5150
Post
by vanhalen5150 » Wed Apr 01, 2015 11:07 am
You can tell that neck was handmade. What's with the back of the headstock? Looks like they couldn't decide what to do there.
Post
by Tone Slinger » Thu Apr 02, 2015 9:04 am
KnE's Franky clones have the high E string positioned closer to the edge of the fretboard as well. My take on it is that both the neck and the pocket were cut to Fender spec.I do not see a gap at either edge of the bodies neck pocket in any photo's. I think the 6 screw bridge mount was what was 'slightly' off,making the high string nearly miss the fretboard. Anyways, I PREFER having the high E closer to the edge of the board. You can get a certain playing touch with it like that, like up in the 17-20 'A pentatonic box'.
popskull
Post
by popskull » Sun Apr 05, 2015 9:52 pm
I may be wrong but it looks like the high E string is caught on the side of a fret somewhere--if you look closely at the nut on the high E string there is some string coming down the neck like on a normal setup gtr then it goes off to the side--has anyone heard about this neck being in a box of junk Ed was going to throw away when someone(don't know who) saw that neck and told him man you should not toss this out
JimiJames
Post
by JimiJames » Mon Apr 06, 2015 9:54 am
Tone Slinger wrote:KnE's Franky clones have the high E string positioned closer to the edge of the fretboard as well. My take on it is that both the neck and the pocket were cut to Fender spec.I do not see a gap at either edge of the bodies neck pocket in any photo's. I think the 6 screw bridge mount was what was 'slightly' off,making the high string nearly miss the fretboard. Anyways, I PREFER having the high E closer to the edge of the board. You can get a certain playing touch with it like that, like up in the 17-20 'A pentatonic box'.
what?
Total dealbreaker... Thanks for the heads up on that particlar body that I'll never get...
Post
by Tone Slinger » Mon Apr 06, 2015 12:08 pm
Here is a pic, not quite as close to the edge as Ed's, but still noticable. I love it like this
- 20150406_1054281.jpg (186.76 KiB) Viewed 1783 times
