For me the Frankenstein Pickup is the right choice. I think the key is the distance from the strings. I had mine too close and it over distorted. I lowered the pickup and it became much clearer and sounds great. For me output equals loudness. That was information that Steve at Dimarzio told me. He made me realize that output is just how loud the thing is. You have a low output pickup; the closer to the strings you are. You get a high output pickup, you move it a bit further away. I took that approach with the Franky pickup in the last week. You have to find that sweet spot. Sometimes lowering it and doing some experimenting will do wonders.
That being said, there are varied tones on all the VH albums. I suspect Eddie swapped picks out all the time.
Question about Duncan's 78?
Re: Question about Duncan's 78?
I`m sure MJ at Seymour Duncan can give you insightEJSLPlexi wrote:Show me when a 78 neck pu has been discussed here?rgorke wrote:exactly, the Duncan Custom is the go to pickup for EVH for me.
That being said, this has been discussed over and over and over and never a resolution.
and FYI this thread is not about trying to get a EVH tone it is about WHY is there a neck pu being offered that was supposedly made for eddie in 1978 when eddie never even used a neck pu back in 78
Yes you are right, i am using the 78 which is 9K and i set closer to the strings and i have my other guitar loaded with the custom wound dimarzio EVH(17.6K) from the EBMM axis guitar.motrock wrote: I think the key is the distance from the strings. I had mine too close and it over distorted. I lowered the pickup and it became much clearer and sounds great. For me output equals loudness. That was information that Steve at Dimarzio told me. He made me realize that output is just how loud the thing is. You have a low output pickup; the closer to the strings you are. You get a high output pickup, you move it a bit further away. .
I do not really like the dimarzio IF i set it close to the strings but backed off i love it as much as the 78.
Steve blucher told me on the phone that the bridge dimarzio in the EBMM guitar is a reproduction of the same pu that was in ed's main stage guitar at the time which was the 5150 kramer so i am guessing it was a JB?
cant think of too many 17K pu's back then
Took your advice and was told it is a specially calibrated model for the neck to go with the 78 bridge model.hammered wrote: I`m sure MJ at Seymour Duncan can give you insight
The neck one has nothing to do with ed at all. it is a duncan only creation.
the bridge one is wound to the exact spec of what seymour had written down when eddie requested a special pu back then
That pu is awesome, i heard your clip with the EVH OD pedal and this guy gets a great tone with itmotrock wrote:For me the Frankenstein Pickup is the right choice. .
https://youtu.be/d31dO6lY7Wg?t=44s
I have several of them ,i think they are killer ,
there so clear and harmonics leap out of them like crazy i turned mr white noise on to them he finally broke down and trusted me (lol) and now he loves them
mike
