My attempt at early EVH tone. . Mean Street
I'm trying to learn how to record guitar. Here's my sloppy rendition of part of Mean Street. I'm not really trying to match the album exactly. . just trying to get a feel for how to get a decent recorded tone.
This is:
Anderson Drop Top with Suhr SSV bridge pickup
Kracke Plexi 50 amp (low watt/variac mode into the upper left input with most everything on 10 except treble channel volume at around
Suhr Reactive Load
Torpedo C.A.B. using Ownhammer 4x12 Mar-CB impulse responses
UAD Apollo Twin Duo running the following plugins:
-UAD 610-B mic pre
-UA 1176 compressor
-EMT 140 plate reverb
Feedback appreciated! I need to try this in a mix next.
https://soundcloud.com/garymct/mean-str ... o-cab-test
This is:
Suhr Reactive Load
-UAD 610-B mic pre
-UA 1176 compressor
- Megaro
Re: My attempt at early EVH tone. . Mean Street
I thought that sounded great. The vibe was definitely there. The eq and ambiance sounded good, too. My only suggestion would be if you can make it sound a little more lo-fi ? Ed had his guitar run through two of those old Eventide H-910s, which has such a unique sound. It gave his whole guitar sound a metallic, yet warm sound. Impossible to put into words, but you know exactly what it is when you hear the guitar hero iso clips. I would say you are pretty much in the ballpark with the rig you have. Keep playing and recording
Nice tones! I have a very similar set up, and I even have the H910 plug in, which sounds outstanding. I don't know why you'd need two of them though? Everything right up to OU812 is pretty much dry / wet whenever it's used. Either the plug in or the H9 Core/Pitchfactor on a second track panned opposite will get that japed tone in spades.
Seriously? I did not know that. The "Mean Street" tone haunts me day and night. To me, that sound the the Holy Grail of rock guitar tone. Do you know where I can read up on the H-910 and how Ed used it, settings, etc? Any help much appreciated. Thank you!Megaro wrote:I thought that sounded great. The vibe was definitely there. The eq and ambiance sounded good, too. My only suggestion would be if you can make it sound a little more lo-fi ? Ed had his guitar run through two of those old Eventide H-910s, which has such a unique sound. It gave his whole guitar sound a metallic, yet warm sound. Impossible to put into words, but you know exactly what it is when you hear the guitar hero iso clips. I would say you are pretty much in the ballpark with the rig you have. Keep playing and recording
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... "Wow! What a ride!"
- Megaro
I will send you a PM so as not to derail the thread and make it into a vintage Eventide thread. But Eddie's tone from Fair Warning is dripping wet with the signature stamp of those wonderful old machines. Listen to the iso guitar clip from Meanstreet and then A/B it with Hang em High. That sort of metallic chorusy sound you hear on Meanstreet is straight up Eventide H910.
- FL6
Is the Chorus on Hang em High?Megaro wrote:I will send you a PM so as not to derail the thread and make it into a vintage Eventide thread. But Eddie's tone from Fair Warning is dripping wet with the signature stamp of those wonderful old machines. Listen to the iso guitar clip from Meanstreet and then A/B it with Hang em High. That sort of metallic chorusy sound you hear on Meanstreet is straight up Eventide H910.
- FL6
I wonder if it's the actual riff too that makes it so appealing, along with perhaps the key or note selection? I get that vibe from Where Have All The Good Times Gone, just so raw but the song itself doesn't have that mystery to it. IDK, doesn't matter really. Awesome tone though and playing.JohnnyGtar wrote:Seriously? I did not know that. The "Mean Street" tone haunts me day and night. To me, that sound the the Holy Grail of rock guitar tone. Do you know where I can read up on the H-910 and how Ed used it, settings, etc? Any help much appreciated. Thank you!Megaro wrote:I thought that sounded great. The vibe was definitely there. The eq and ambiance sounded good, too. My only suggestion would be if you can make it sound a little more lo-fi ? Ed had his guitar run through two of those old Eventide H-910s, which has such a unique sound. It gave his whole guitar sound a metallic, yet warm sound. Impossible to put into words, but you know exactly what it is when you hear the guitar hero iso clips. I would say you are pretty much in the ballpark with the rig you have. Keep playing and recording
- fivecoyote
I wouldn't call it dripping wet -- not how I hear it personally. More wet on the solos for sure. The best way I can describe it is it sounds a little "hi fi" -- a much lesser version of what he did with his Sammy sound. FW guitar also sounds less "clangy" to me, warmer, which is why some have speculated it's a Les Paul on there or an EL34 head, etc. No evidence for either and my 2c is it's neither, but for sure it's different -- also different tones within that album, same as all the albums. How I hear 'em anyway.
Re: hi fi -- to my ears a cheaper, similar way to get that sound is with the EBMM (particularly) or DiMarzio TZ/AT pickups. Of course you give something up but....
At it awhile, still learnin'
- garbeaj
I tend to agree with fivecoyote...the way I hear "Mean Street" and Fair Warning in general is that the Eventide is used mostly for leads. I don't hear Eventide on the main riff and rhythms in "Mean Street" at all. But the Eventide is definitely all over the leads and overdubbed leads.
Here's a clip I made of me playing an overdub that occurs at the end of "So This Is Love?" which has upper and lower octave sounds from the Eventide. I'm using my H9 to simulate the sound, along with my vintage MXR Flanger:
I hear plenty of Eventide effect on the main riff in that song. And the tone in the op''s clip is fantastic to my ears.
- Megaro
It's the other way around. The solo is pretty dry. A good iso will allow you to hear the punch ins and also the different eq treatment. Pretty trebley. But, the Eventide is all over the rhythm. It is not very subtle either. Grab a good quality iso and listen in with headphones. I have an old iso from the way back where I can split the guitar track into left and right. But, the main thing that sets Meanstreet apart on the rhythm is a little touch of octave care of the Eventide H910. You can also hear what sounds like some flanging going on, but that is actually part of the pitch shift on those particular models. I am pretty sure the mix is the dry guitar with about a .98 detune shift and its delay which comes with the package deal on that model, maybe a +2 upshift, and then on top of that, ever so subtly is the full step down. For some reason, a 2 cent change on those old Eventides is so much more prominent than a 2 cent change even at 100% wet on the newer Eventides (anything after the H3000). I think that subtle octave down is why much of the guitar on Fair Warning sounds so ominous.
