Check My Work For Me
- winnard
The lighting on the pic isn't very good, but here's what I have done so far.
I messed up two resistors, no biggie, I'll check Radio Shark tomorrow for them. I don't have the caps installed yet, I emailed George for some info on the voltage on them. They are (.022s) 400v instead of 630v. Does it matter? I'm going to order some more Sozo's for the PTP, since I used the ones I had on the PCB'd 1959slp.
winnard
winnard
The only thing i see is your diodes look fishy. The bias recto diode looks to be oriented in the wrong direction and the bridge recto diodes are abnormal. The bridge will work that way but its not 'standard'. The way you have it the PT HV secondary would solder in on the 'sides' of the square while the bridge negative would be on the bottum of the board in the pic while the DCB+ will be on the top in the pic. Its a common mistake but one sure way to possibly do some damage. Make sure you know how to orient them.
- winnard
Please, any tips are greatly appreciated. I can take a better closeup picture of them, if you can direct me to the proper direction.Billy Batz wrote:The only thing i see is your diodes look fishy. The bias recto diode looks to be oriented in the wrong direction and the bridge recto diodes are abnormal. The bridge will work that way but its not 'standard'. The way you have it the PT HV secondary would solder in on the 'sides' of the square while the bridge negative would be on the bottum of the board in the pic while the DCB+ will be on the top in the pic. Its a common mistake but one sure way to possibly do some damage. Make sure you know how to orient them.
Thanks,
winnard
- Dax-The-Ax
I think you are missing a jumper wire on your bias pot Turret (Black Arrow).
And if it's a 1959, the + (Light Grey) end of the diodes need to go in the direction of this pic.
- winnard
- winnard
Dax-The-Ax wrote:I think you are missing a jumper wire on your bias pot Turret (Black Arrow).
The picture is gone. Could you email it to me? 8track1@cox.net
thanks.
winnard
- Flames1950
- winnard
Cool, thanks. I'm going to fire it up with the Mallory caps, and switch them out later, (if it warrants). Heck, I might even like them.Flames1950 wrote:Sheesh, does anyone around here sleep at night?
On the cap voltage subject 400 volt caps are just fine on the board. SoZo's are typically 400V for .022's but the Mallories are sometimes easier to get a hold of in the 630V so you sometimes get a mix of Mallories.
winnard
- Flames1950
It's not that you won't like the Mallories; they're good caps. The SoZo's are just that little bit more that we all seem to like: a little more clarity, a little more bite, a little more "Marshall."
I'm starting off with the Mallories in my Metro kit. I don't know if I'll get around to changing them out for SoZo's or not (I do still have three or four SoZo's around too.)
