I tried swapping out the preamp tubes one by one with a known good one from another amp and the problem did not go away. I inspected (and tested continuity with my meter) all of the wiring from the normal channel up through to the mixer resistors and found no problem.
The fact that it seems to take a few minutes to occur after starting up the amp cold makes me think that it's a connection that gets iffy once it gets heated up. This makes me wonder if it's a problem with one of the tube sockets (maybe the normal channel side of the V1 socket?). I didn't notice anything weird while watching the tubes when I was playing.
I'm trying to figure out what my next step should be - maybe fire the amp up on the bench (let it warm up for a few) and try the chopstick/pencil method to test out all the connections and the terminals of the preamp sockets? Any ideas?
Eamon
