Heater Wire Help
- guitar007
- monsterwalley
someone posted somwhere a while back about using a cordless drill.
I tried it on my first build and it worked pretty good. On my second build
I just took my time and it still turned out pretty good. I used zip ties and tape to hold things in place until I soldered everything. I'm sure there are slicker ways though......
jim
- Joe Popp
PTFE Wire (Teflon coated silver plated stranded) holds it's shape well too. Just tape 2 ends together and pu them in a cordless drill. Twist them but not too tight. Cut into sections and unwind a few inches for your solder connections.
Here's a great link from Brownnote:
http://www.brown-note.com/heaters/
- Wicksy
- Rootz
+ 1 on Simon's method. I do it by hand and that works great. If you use a drill you have to untwist some wire. The untwisted parts will look crooked. I use aligator clamps to hold the wire in place, or a pair of pliers, actually anything that works, also tape. It just takes a lot of patience to get the wiring neat. Patience is probably the key ingredient!
Bas
SOUNDS http://www.soundclick.com/rootz0001
TEST DEPARTMENT http://www.soundclick.com/rootztestdepartment
JTM45 PICTURES http://picasaweb.google.nl/fotosvanmb/MetroJTM45
JTM50 PICTURES http://picasaweb.google.nl/fotosvanmb/JTM50
+2!!Rootz wrote:+ 1 on Somon's method. I do it by hand and that works great. If you use a drill you have to untwist some wire. The untwisted parts will look crooked. I use aligator clamps to hold the wire in place, or a pair of pliers, actually anything that works, also tape. It just takes a lot of patience to get the wiring neat. Patience is probably the key ingredient!
I can't use a drill for the reason you just mentioned. Fingers all the way! lol
That pre-tinned wire Simon mentioned is great for the heaters.
- guitar007
