Where do I place Premium Sozos?
Mars Hall
Post by Mars Hall » Mon Nov 03, 2008 8:13 pm
Hi everyone,
I purchased premium Sozos for my BBRI PTP board. I only bought enough for a JTM45. I didn't think the tremolo circuit warranted the premiums. Where do I put them, when I populate the board? My disc shows the JTM45 layout. Is the tremolo section everything on the far right? I would use the premiums on everything from the left, till I run out? Minus the presence pot. I want to make sure I use the premiums in the most valuable positions.
jbzoso2002
Re: Where do I place Premium Sozos?
Post by jbzoso2002 » Mon Nov 03, 2008 10:16 pm
hi jerry call me if you want but with the pots faceing you
there's a diode for the bias feed. everything left is
jtm 45.
jimmy 8)
Post by Roe » Tue Nov 04, 2008 10:19 am
the 2 .022s after v1 and the 2 .1s in the pi/output section
