45 100 layout question
BLOOZE
Post by BLOOZE » Thu Jan 26, 2012 10:51 am
I m working on my 45 100 and
I wonder if turning around the 8k2 that connects to v4 pin 6 makes a cleaner built.
How are the originals wired – on the pics from amparchive ,george and chris m this 8k2 resistor is connected on the tube side.
from amp archives
has there been a 45 100 with preamp filter 32uf on board or should this be a 16uf - ?
i know about the 32uf + 32uf filtering
Re: 45 100 layout question
Post by Roe » Thu Jan 26, 2012 11:52 am
yes, originals had the 8k2 turned around (compared to the layout). they had 16uf on the preamp although the dickinson amp, and some 67 amps, had 32+32
BLOOZE
Post by BLOOZE » Thu Jan 26, 2012 12:03 pm
Roe wrote:yes, originals had the 8k2 turned around (compared to the layout). they had 16uf on the preamp although the dickinson amp, and some 67 amps, had 32+32
Roe - great thank you for your help
i m building a 12xxx clone too - are the resistors(10k and 8k2 ) also turned around (compared to the layout).
Post by Roe » Fri Jan 27, 2012 3:30 am
yes, that one is also turned around
Big Mike
Post by Big Mike » Tue Jan 31, 2012 12:43 pm
I'm not following 'turned around' ?
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
BLOOZE
Post by BLOOZE » Wed Feb 01, 2012 10:13 am
Big Mike wrote:I'm not following 'turned around' ?
Question was about, were the orig 45 100 or 12xxx connects the choke with the 8k2...............
I will connect it on the tube side of the board………on the layout the choke is connected at the potentiometer side of the board…………….
