Okay, I got the amp up and running, biased the tubes, and plugged it in via my MASS (it's late). It sounds good, but when I dime the volume, on the treble channel I get a feedback-like squeal, and on the normal channel I get an almost tremolo-like oscillation sound.
What could this be? The only thing I've noticed from the kit instructions I didn't do is twist the wires that lead from pin 5 on the output tubes to the board, but they weren't when the other board was installed. Thoughts?
Oscillation/squealing when volume on 10
Q: Can you turn your amp down so I can put you in the PA?
A: No.
A: No.
- NY Chief
- Wiki Editor
Sounds like the shielding plate problem. Is the head in cab? Does the cab have the metal plate underneath the chassis? Mine did the same thing out of the cab. I installed the plate (alum flashing from the Depot is fine) in the head box and pur the chassis in. Problem gone.
Yeah, I checked the other posts about this problem while waiting for a reply, and they all indicated that having the chassis out of the headbox was the main cause of the problem. I'll throw it back in the headbox (wich does have the metal plate in it) and see if that solves things. Thanks!
A: No.
A: No.
