alternative materials for circuit board?
- Kevin
hey fellas,
i'm looking for circuit board material and am wondering whether there are any readily available materials which are suitable for sombebody who is not particularly concerned with look and authenticity.
which properties make a material suitable for use as a circuit board? would plexiglass or a similar acrylic panel be suitable? any other suggestions?
thanks in advance.
kevin
thanks in advance.
kevin
- Flames1950
http://www.mcmaster.com/
Go down to raw materials (?) and click on plastics........
I'd hesitate to try acrylic in case it cracks when you stake the turrets in.....it doesn't respond well to pressure.
- VelvetGeorge
- Site Owner
- Kevin
- Guitar Adjuster
Well, the link referenced above (McMaster-Carr) also sells phenolic as "Garolite" in the XX grade. You can get a small piece and experiment to see if you like it, or they sell a sample pack for about $10.
I don't know if George has tried the same stuff I got, but he has had bad luck with some phenolics, so I'm referencing his post here:
http://forum.metroamp.com/viewtopic.php ... t=phenolic
